Hello all, Just switched from domoticz to home assistant, so trying to find my way again. I Installed a zwave usb stick in home domoticz and is working fine with some components. I just received two neo cam remotes ‘sos 4’ remote with four key buttons. I added it ass secure node and all went well. Thing is i don’t know how to ‘map’ the keys. One thing is it doesn’t switch states, so can’t use simple automation. I know and read in the HA log that there were scenes but i cant find them in HA.
Is homeseer switches the way to go? (For the HomeSeer devices specifically, you may need to update the COMMAND_CLASS_CENTRAL_SCENE for each node in your zwcfg file with the following:)
Can someone point me in the right direction?
Thanx all,
Logbook
Showing entries for
25 mei 2018
19:12
changed to sleeping
19:12
Neo CoolCam SOS/Remote Control Emergency changed to 1
19:12
Neo CoolCam SOS/Remote Control SourceNodeId changed to 0
19:12
Alarm Level changed to 0
19:12
Alarm Type changed to 0
19:12
Sensor turned on
manual
Advanced Configuration
The following information is written to some people who have some experience in building a Z-Wave system or have a software that can run a Z-Wave master device or a Z-Wave alarm host. Be familiar with the Z - Wave master or Z - Wave alarm host before setting up.
- Basic Set Level
Basic Set Command will be sent where contains a value when SOS is triggered if group 2 have associated a device such as siren, the receiver will take it for consideration; for instance, if associated siren is received the Basic Set Command (0xFF), the siren will take alarm on.
0~99 are mapping to Basic Set value (0 ~ 99). 100 is mapping to Basic Set Value 0xFF.
Parameter Number Size Available Settings Default
1 1 0 ~ 100 100
- SOS Event Clear Time
This parameter defines the time to clear emergency event after emergency event is triggered when parameter #3 is set to ‘2’.
This parameter is set to ‘0’, the clearing emergency event will not occurred always.
The default value of this parameter is set to ‘60’, means that the emergency event will be cleared after 60 seconds when emergency event is triggered.
2 2 0 , 30 ~ 32767 60
- SOS Configuration
This parameter defines the SOS key function, the SOS key can be configured as emergency event key or central scene notification key.
If this parameter is set to ‘1’, the SOS key will be configured as central scene notification key.
If this parameter is set to ‘2’, the SOS key will be configured as emergency event notification key. The default settings is ‘2’, the SOS key is configured as emergency event notification key.
3 1 1, 2 2
Command Classes
This Sensor supports Command Classes as Below:
COMMAND_CLASS_ZWAVEPLUS_INFO (V2)
COMMAND_CLASS_VERSION (V2)
COMMAND_CLASS_MANUFACTURER_SPECIFIC (V2)
COMMAND_CLASS_DEVICE_RESET_LOCALLY (V1)
COMMAND_CLASS_POWERLEVEL (V1)
COMMAND_CLASS_BATTERY (V1)
COMMAND_CLASS_ASSOCIATION (V2)
COMMAND_CLASS_ASSOCIATION_GRP_INFO (V1)
COMMAND_CLASS_WAKE_UP (V2)
COMMAND_CLASS_NOTIFICATION (V8)
COMMAND_CLASS_SENSOR_BINARY (V2)
COMMAND_CLASS_CONFIGURATION (V1)
