Neolink addon installation
I have installed the Neolink Addon. After starting it gives the next error:
Neolink e47a0d5734b0a06b53bd8d78be9ca2f6b8396480 release
Error: Failed to read “/config/addons/neolink.toml”
But I use the following version:
  • Core2024.6.4
  • Supervisor2024.06.2
  • Operating System12.4
  • Frontend20240610.1
    I have no access to /config/addons I think.
    Where should I put that file?
Regards
Poul
If you are having a problem with a specific Add-on, the first point of contact is in the Github post that you found it in originally.
Most if not all the people there that know the product and use the software that will be able to give you more accurate information regarding your problem.
Here you might find someone.
In this case it may need an update to the code to account for the HA directory name change from ‘config’ to ‘homeassistant’, so ask about that.
