A few days ago my thermostats suddenly stopped working through home assist. Troubleshooting online suggested removing the integration and setting it up fresh. But now I can get them added back. I’ve run out of things to try so I’m hoping someone has suggestions for what I can try next. Here are the logs related to the issue.
Logger: homeassistant.config_entries
Source: config_entries.py:761
First occurred: 1:52:49 PM (2 occurrences)
Last logged: 1:53:06 PM
Error setting up entry Home for nest
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 761, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/nest/init.py”, line 218, in async_setup_entry
subscriber.cache_policy.store = await async_get_media_event_store(hass, subscriber)
File “/usr/src/homeassistant/homeassistant/components/nest/media_source.py”, line 91, in async_get_media_event_store
await hass.async_add_executor_job(mkdir)
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 59, in run
File “/usr/src/homeassistant/homeassistant/components/nest/media_source.py”, line 89, in mkdir
os.makedirs(media_path, exist_ok=True)
File “”, line 228, in makedirs
OSError: [Errno 74] Bad message: ‘/config/nest/event_media’
