I think he means on chrome > 3 dot menu > more tools > dev tools > network tab
this lets you see debug/source/etc info on the web pages
Yes that’s what I mean. But the latest release fixed your fan control issue so there is no need to capture the payload.
Sorry, I can’t believe I missed that. ![]()
I hoped that the update will show my thermostats, but it didn’t. Sad face ![]()
Can I help you somehow? Do some diagnostics, maybe at home.nest.com?
Hello – Google announced that Gen 1/2 thermostats can no longer be remotely controlled at the end of this month. Will this legacy integration continue to work afterwards? I presume not, as it still relies on Google’s cloud services, correct?
Correct. I don’t see how this could continue working
I’m trying to get this working using Legacy Nest Account Configuration. It accepts my access token but during the initializing phase I only get this error:
Failed Setup, will retry: Failed to initialize Nest: invalid literal for int() with base 10: ‘none’
Can you enable debug logs and attach them in a new GitHub issue?
I am struggling to get the integration working, receive the following error:
Failed setup, will retry: Failed to initialize Nest: ‘serial_number’
I filed an issue on Github with the log.
This is exactly what I wanted as it will solve one of the biggest problems in my home, the nest thermostat. I do not want to give even more money to google than I have to. I added this integration to my HA and it was able to find my door lock. However, it did not add my gen 3 nest thermostat. I already see that this issue is already on GitHub. Great work so far!
Context:
Google semi-bricking Gen1 and Gen2 Nest thermostats and not providing a way of opening them up to local control. FULU bounty won (although weirdly the Fulu page not updated?).
Github for that here
There is also a Home Assistant addon!
Try the latest version. It should be working now.
@tronikos i am try to activate a change in temperature programmatically via appdaemon. is that possible at all?
i have tried setting either the temperature or target_temp_high attributes to the desired value and the hvac_action to ‘heat’ but it’s not activating the change. any clues or is this not possible?
everything else is working as expected in the UI
I don’t use AppDaemon. If the same works in the UI I assume it’s either a user error or an AppDaemon issue. Does it work if you call the action in developer tools > actions? If yes you should ask for help wherever AppDaemon is discussed.
it was a case of me calling the wrong service, or action as it’s known in the UI. it’s working now.
self.call_service('climate/set_temperature', entity_id=const.HEATING, temperature=target, hvac_mode='heat')
and the equivalent yaml was
action: climate.set_temperature
entity_id: climate.heating
temperature: 23.5
hvac_mode: heat
For me it does not discover all thermostats. I have 4, 2 gen2 and 2 gen3. The legacy nest only discovers 1 of them (a gen3 one)
Currently, I have been using two separate HA Nest integrations for my Gen 3 Nest Thermostats and Remote sensors.
This is all fine and good when the controlling sensor is the thermostat itself as I can then read both sensors independently.
When the controlling thermostat switches to the remote sensor, then both integrations read the remote sensor and I have no way to read the actual thermostat sensor on the device from HA.
Will your integration allow me to read both sensors independently? (temperature/humidity on the thermostat and temperature on the remote sensor)
Does your integration allow one to:
Conversely, is there anything that Nest Protect does that your integration doesn’t do or that it does better? (said another way, if I can get your integration working, is there any reason to still use Nest Protect or is your integration a superset for the purpose of thermostat and remote temperature sensor control)
I would like to avoid having 3 separate integrations for 1 stinkin’ Google thermostat ![]()
Thanks!
Yes it should. If not, open a GitHub issue with debug logs.
Nest Legacy is a superset of the Nest Protect integration. There is no reason to have the Nest Protect if you install Nest Legacy.
That’s amazing!
Would be great if you could support #1 (switching control between native and remote sensors) as I would like to add that to an automation.
Thanks!
Couple of additional questions:
What does “occupancy” do and/or how do I control it? It seems to just show “clear” on all my thermostats
I get entities created for “target humidity”, “filter_runtime” and “filter_replacement_needed” but I have never seen those before on either the thermostat itself or the Nest or Google Home app? Are they even relevant for a Nest Learning Thermostat (Gen3) used on a gas furnace
Is there any way to turn on-off “Farsight/Wake-on-Approach” mode (used to automatically turn on/off the display) from the API?
