I have Nest set up to the point where I can get it to ask me for the pin number, and I can generate the pin number, enter it, and hit confirm. After this, it just sits there. It says it “Called configurator” but does nothing.
A few messages.
2017-12-07 22:38:53 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:True [Try again]
2017-12-07 22:38:54 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 80: [Errno 99] error while attempting to bind on address ('192.168.2.13', 80): address not available
2017-12-07 22:39:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
If you want, I could post more. But after this point it was basically just this exception causing a ton of other exceptions.
I’m not sure if it’s related to the other issues I have been having, such as not being able to connect to PiHole or the Configurator, and the Yr sensors are stuck at “unknown”
