Docs need some updating to adjust for Nest Protect support. So instead of thermostat, what specific string goes there now? protect, nest protect, nest_protect, nestprotect?
And sensor configuration docs also needs some specificity:
I just answered my own question on another thread looking for the same info.
If you’re just using the Nest Protects, then omit the thermostat line and all monitored conditions but battery_level and the last two. When you restart HA, they will show up in the dev panel entities as sensors. Not sure if the Protect sends anything else but I am still testing.
What I still haven’t figured out is the available states for CO and Smoke; in normal conditions, the state is “OK” but there is no documentation about the other states; is it “Not OK”/“Some String” or an actual level value or…
Strange. The only time I got errors was when I tried to use any of the other monitored conditions. Otherwise it worked as soon as I removed the thermostat line. Do you have any other sensors? If so, you’ll have to add a number to your nest sensor. Your first sensor is sensor, next is sensor 2, sensor 3 and so on.
Sorry to pull up and all thread but I happen to be having the exact same issue as you are. I’m wondering if you ever got it working and if so how did you get it to work?
Are you not seeing the Protects? Be advised that there was a code change which caused them to show unknown for a bit but it was recently corrected by the PR which was merged to .33.2:
They’re not exposed in the API as far as I know. The ‘temp’ sensor is actually just a heat sensor that detects sudden rises in temp only and the ‘humidity’ sensor is used only to reduce nuisance alarms caused by things like steam from your shower.
I think both are just used internally to reinforce the detection algorithms.
I too would be very interested in gaining more sensors from my Nest Protect. in particular motion detection, which is used for the build in ‘night light’. Having this trigger other lights would be great.
I’m in the process of switching from HomeBridge to Home Assistant. It appears that the current Nest Integration does not support motion detection, but whoever wrote the HomeBridge Nest module has figured out how to pull that sensor’s status.
