Nest Sensor as Thermostat
Hello-
Can I trigger events using the Nest sensor, or do I need to use the thermostat for that? I would like to essentially use the sensor as a thermostat by having it turn an AC on within a target range.
If the answer is no, what is a good alternative, short of buying a smart thermostat? Build a temp / humidity sensor with an ESP8266 and use MQTT protocol to publish to HA?
Thanks!
