Hi All,
I’m using a slider to set the template of my nest when I sleep and wake.
Here is what I have with the slider and the script to trigger the temperature values:
input_slider:
slider1:
name: Night Temprature
initial: 20
min: 17
max: 22
step: .5
slider2:
name: Day Temprature
initial: 20
min: 17
max: 22
step: .5
script:
morning_temp:
sequence:
- service: climate.set_temperature
entity_id: climate.entryway
temperature: '{{ states.input_slider.slider2.state | float }}'
night_temp:
sequence:
temperature: '{{ states.input_slider.slider1.state | float }}'
When I run the script, the Nest temp doesn’t change. I think it might be how I target the slider. I’m not sure.
Thank you for your help
