Nest Thermostat configuration flow in progress
I am attempting to configure my Nest Thermostat in Home Assistant. I started the configuration, but got some of the information incorrect the first time, so I am now trying again. I have deleted the existing credentials in Settings > Devices & Services > Application Credentials.
When I go through the setup screens, I am able to get right to the end, then I get “Configuration flow is already in progress”. There are no other options to continue, and deleting the existing credentials and starting over doesn’t seem to change anything.
Bumping this. I’ve still not found a solution to my issue.
I am having this same issue.
Having the same issue!!
Having the same issue also
Reboot your home assistant server and it fixed my issue
