Netamo integration
when home assistant restarts, the netatmo integration is not loaded. It is necessary to cancel the application and reinstate it. this happens for both cloud mode and yaml.
can this problem be solved?
Please turn on debug mode for the integration and provide relevant log messages.
2022-01-09 16:51:21 INFO (MainThread) [homeassistant.components.climate] Setting up climate.netatmo
2022-01-09 16:54:22 INFO (MainThread) [homeassistant.components.select] Setting up select.netatmo
2022-01-09 16:54:22 INFO (MainThread) [homeassistant.components.climate] Setting up climate.netatmo
2022-01-09 16:57:24 INFO (MainThread) [homeassistant.components.select] Setting up select.netatmo
2022-01-09 16:57:24 INFO (MainThread) [homeassistant.components.climate] Setting up climate.netatmo
This is still missing relevant information. If nothing else helps and there aren’t any debug messages in your logs I’d suggest to remove and re-add the integration.
