Netatmo authentication problem
I am adding the Smart AC Controller device in the Netatmo integration. I can have it work on my local dev instance if I overwrite authentication token with my token (The one I got with my own netatmo application written in js). But If I use the token obtained through HA authentication, it works but it does not get the same answer from netatmo api. There are less devices in the answer. ANd there is no NAC device in it. Below are the answer of Netatmo api with my token and with ha token. Any help to undestand the problem ?
curl -X GET "https://api.netatmo.com/api/homestatus?home_id=652ac4ee1b353231dd049bc3" -H "accept: application/json" -H "Authorization: Bearer  b4508278ef7-----------------|13ab80da6770d9b4-------------------"
"response": {
        "status": "ok",
        "time_server": 1739695743,
        "body": {
          "home": {
            "id": "652ac4ee1b353231dd049bc3",
            "modules": [
                "type": "NAMain",
                "firmware_revision": 204,
                "wifi_strength": 66,
                "last_status_store": 1739695327,
                "co2_calibrating": false,
                "hw_version": 202,
                "id": "70:ee:50:a5:ad:6e",
                "Temperature": 23.8,
                "temperature": 23.8,
                "CO2": 742,
                "co2": 742,
                "Humidity": 40,
                "humidity": 40,
                "Noise": 44,
                "noise": 44,
                "Pressure": 1014.1,
                "pressure": 1014.1,
                "AbsolutePressure": 1010.9,
                "absolute_pressure": 1010.9,
                "time_utc": 1739695742,
                "ts": 1739695742,
                "min_temp": 18.6,
                "max_temp": 23.8,
                "date_max_temp": 1739694722,
                "date_min_temp": 1739684431,
                "temp_trend": "up",
                "pressure_trend": "down",
                "homekit_status": "configured",
                "wifi_state": "high"
                "id": "02:00:00:a4:87:2c",
                "type": "NAModule1",
                "battery_level": 5382,
                "last_message": 1739695737,
                "last_seen": 1739695724,
                "rf_strength": 58,
                "firmware_revision": 53,
                "reachable": true,
                "Temperature": 10.2,
                "temperature": 10.2,
                "Humidity": 80,
                "humidity": 80,
                "time_utc": 1739695314,
                "ts": 1739695314,
                "min_temp": 7.3,
                "max_temp": 10.2,
                "date_max_temp": 1739695314,
                "date_min_temp": 1739675320,
                "temp_trend": "up",
                "hw_version": 11,
                "bridge": "70:ee:50:a5:ad:6e",
                "battery_state": "medium",
                "rf_state": "full"
                "aps_key_pair_amount": 3,
                "busy": false,
                "configure": false,
                "configured": true,
                "connection": "wifi",
                "firmware_revision": 901,
                "firmware_revision_factory": 120,
                "hardware_version": 218,
                "id": "00:04:74:35:35:fc",
                "last_configs_update": 1739695500,
                "last_seen": 1739693236,
                "local_ipv4": "192.168.1.15",
                "local_ipv6": "FE80::204:74FF:FE35:35FC",
                "offload": false,
                "offload_meters": [],
                "open_zigbee": false,
                "otau_downloads": 0,
                "packaging": "mobile",
                "product_configuration": "no_configuration",
                "reachable": true,
                "sequence_id": 89618,
                "spi_alive": true,
                "subtype": "standalone",
                "timestamp": 1739695742,
                "type": "NLG",
                "uptime": 7046071,
                "use_pincode": false,
                "wifi_strength": 20
                "brightness": 100,
                "configured": true,
                "firmware_revision": 35087696,
                "id": "f0:d1:b8:00:00:1d:3b:9f",
                "last_seen": 1739695625,
                "last_user_interaction": 1739658251,
                "on": false,
                "power": 0,
                "power_source": "mains",
                "reachable": true,
                "type": "Z3L",
                "uptime": 7046071,
                "variant": "Z3L:generic_dimmable_light",
                "bridge": "00:04:74:35:35:fc"
                "battery_level": 2600,
                "configured": false,
                "firmware_revision": 77,
                "id": "00:04:74:00:00:c4:38:68",
                "last_seen": 1739658251,
                "power_source": "battery",
                "reachable": true,
                "subtype": "on_off_remote",
                "type": "NLT",
                "uptime": 7046071,
                "variant": "NLT:remote_control_on_off_dimmer",
                "bridge": "00:04:74:35:35:fc",
                "battery_state": "high"
                "brand_id": 0,
                "command_received": false,
                "current_protocol": "92000",
                "fan_end_time": null,
                "fan_mode": "auto",
                "fan_setpoint_from": "parent",
                "firmware_revision": 1030,
                "hardware_version": 223,
                "id": "70:ee:50:ad:1d:06",
                "operating_mode": "ready",
                "protocol_list": ["70386", "92000", "36715", "2114"],
                "protocol_validated": true,
                "sequence_id": 82615,
                "type": "NAC",
                "vertical_fan_swing_mode": "auto",
                "wifi_strength": 40
            "rooms": [
                "anticipating": false,
                "humidity": 49,
                "id": "4101059324",
                "reachable": true,
                "therm_measured_temperature": 21.2,
                "therm_setpoint_end_time": null,
                "therm_setpoint_mode": "home",
                "therm_setpoint_start_time": 1739684504,
                "therm_setpoint_temperature": 22
curl -X GET "https://api.netatmo.com/api/homestatus?home_id=652ac4ee1b3532----------" -H "accept: application/json" -H "Authorization: Bearer 6517be478e1--------------|43c1ff0b8f4abd4-----------"
"response": {
        "status": "ok",
        "time_server": 1739695762,
        "body": {
          "home": {
            "modules": [
                "type": "NAMain",
                "wifi_state": "high",
                "wifi_strength": 63,
                "ts": 1739695758,
                "co2": 726,
                "humidity": 40,
                "noise": 49,
                "pressure": 1014.1,
                "rf_state": "full",
                "rf_strength": 58,
                "reachable": true,
                "ts": 1739695314,
                "humidity": 80
                "type": "NLG",
                "offload": false,
                "wifi_strength": 20,
                "reachable": true,
                "type": "Z3L",
                "on": false,
                "brightness": 100,
                "power": 0,
                "reachable": true,
                "type": "NLT",
                "battery_state": "high",
                "reachable": true,
