Netatmo_event never fires
I have the same problem, netatmo_event isn’t available. I tried everything, spent 8 hours on the issue. Nothing helps. Strange is the webhooks are working perfectly and I can see them in the DEBUG log. But not one netatmo_event is fired. I am very interested to solve the issue. There must be an issue in between webhooks and events. @cgtobi do you have an idea what I should try next?
The issue started for me, when I switch from yaml to the WebUI Integration.
Here is what I noticed: Netatmo camera webhook behaviour changed in December
Finally I am receiving events, in the Netatmo dev panel I had to fill redirect + webhook URL with my external address and now it’s working
Hi, how did you manage that?
This used to work for me a long time ago, but I’m unable to set it up again.
In my old app configuration, I had webhook URI configured to https://<dns_name>/api/webhook/, where did you get this from?
Thank you
