Netatmo Integration Issues
Hi all,
Just back from holiday to find some of my automations controlling my shutters (roller blinds) are not working. When I go into the room on my dashboard and try to operate it as a device I get this message:
“This entity is no longer being provided by the netatmo integration. If the entity is no longer in use, delete it in settings.”
Is this something:
a). I have done?
b). I have been notified about and missed?
c). An update has done?
d). Netatmo has done?
Is there a solution please? I am looking at HomeKit to try to overcome the api limitation issues but not sure if this will work if the Netatmo integration is not recognising the roller blind switches.
Anyone else experiencing this?
Do I need to delete it from settings and try to reinstall it?
Apologies, I forgot to mention that I can control it through the Legrand Control app. Do automations ans scenes in that app conflict with HA or does HA control override the native app through the integrations?
OK, this is really weird. I disabled one of the shutters then re-enabled it and it worked.
When I then checked the other shutters they too are now all working.
Is there anything I can look at in logs that might explain what happened or should I just ignore it!
