I installed the component and all was working fine but after a reboot of Hass I haven’t anymore the Netatmo stream cameras devices on the dashboard.
Others devices like Temperature , Noise, Humidity work fine.
I have this message in the log
Error while setting up platform netatmo
10:19 components/camera/netatmo.py (ERROR)
Tue Feb 20 2018 10:19:17 GMT+0100 (Paris, Madrid)
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 84, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/camera/netatmo.py", line 49, in setup_platform
camera_type, verify_ssl)])
File "/usr/lib/python3.6/site-packages/homeassistant/components/camera/netatmo.py", line 68, in __init__
camera=camera_name
File "/usr/lib/python3.6/site-packages/smart_home/Camera.py", line 165, in cameraUrls
temp_local_url = resp['local_url']
TypeError: 'NoneType' object is not subscriptable
I’m newbie so I don’t know what means the message …
I have the same problem. The camera has always worked very well, but since yesterday I have the following message: camera not available. Others devices work fine (température, Humidity…).
In Dev-state section < >, the entitie camera.home has disappeared
Same Logs Errors:
Blockquote
Log Details (ERROR)
Tue Mar 27 2018 09:45:54 GMT+0200 (Paris, Madrid (heure d’été))
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 82, in async_setup
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/camera/netatmo.py”, line 49, in setup_platform
File “/usr/lib/python3.6/site-packages/homeassistant/components/camera/netatmo.py”, line 68, in init
camera=camera_name
File “/usr/lib/python3.6/site-packages/smart_home/Camera.py”, line 165, in cameraUrls
temp_local_url = resp[‘local_url’]
TypeError: ‘NoneType’ object is not subscriptable
Problems with Python?
I do not think the problem comes from Netatmo, because the camera works well under ImperiHome program.
Hi, I have a question for you, owners of a Netatmo welcome camera.
Is it possibile to see the live stream of the camera in home assistant by using the Netatmo Camera component?
The documentation only says:
This component allows you to view the current photo created by the Camera.
Hello, I’m also getting the same issue with presence detection from the netatmo components, here’s the error in my logfile:
2018-12-16 00:31:00 ERROR (MainThread) [homeassistant.helpers.entity] Update for binary_sensor.front_outdoor_vehicle fails
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/binary_sensor/netatmo.py", line 157, in update
self._data.update_event()
File "/usr/local/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 324, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/netatmo.py", line 119, in update_event
home=self.home, cameratype=self.camera_type)
File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 255, in updateEvent
eventList = resp['body']['events_list']
Did you ever fix the issue? My camera is still working, but I’m still getting the errors occasionally, so could it just be network issues?
Quick question: how are Netatmo cameras shown in HA? Live stream or some recent photo? The same for both Welcome and Precense? The API doesn’t say it very clearly…
I get the ”stream” via camera component, but it is not video. It’s a picture that updates about once per 2s. Is it possible to get the actual video? The same that is shown in the Netatmo app?
To be more specific. If I click on the image the update rate is about 1/2s. Without clicking the update rate is about 1/8s. Is it possible to get the actual stream visible?
Can’t remember exactly. I already had the weather station and I would like to say I did not have to do anything, the integration was already there. Should I do it again? Should the stream be better?
Seems that Netatmo integration was done so long ago that it was done via Configuration.yaml. Is this the reason for a poor stream?
since I updated to 0.118 I get an error when I try to record the Netatmo Presence Stream:
2020-11-19 16:36:00 ERROR (recorder_save_worker) [libav.mov,mp4,m4a,3gp,3g2,mj2] moov atom not found
2020-11-19 16:36:00 ERROR (recorder_save_worker) [root] Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/src/homeassistant/homeassistant/components/stream/recorder.py", line 43, in recorder_save_worker
source = av.open(segment.segment, "r", format=container_format)
File "av/container/core.pyx", line 354, in av.container.core.open
File "av/container/core.pyx", line 225, in av.container.core.Container.__cinit__
File "av/container/core.pyx", line 257, in av.container.core.Container.err_check
File "av/error.pyx", line 336, in av.error.err_check
av.error.InvalidDataError: [Errno 1094995529] Invalid data found when processing input: '<none>'; last error log: [mov,mp4,m4a,3gp,3g2,mj2] moov atom not found
2020-11-19 16:36:07 ERROR (MainThread) [homeassistant.components.generic.camera] Error getting new camera image from einfahrt_camera: Response payload is not completed
