Hi all, I have noticed that recently the netatmo main thermostat entity “living” is not showing anymore the actual boiler status but only when it is itself below threshold. Before it was “green” (ON) both in case the main thermostat temperature was below the threshold or in the case whatever other thermostat was, practially showing the boiler ON status. Main thermostat is configured in comfort mode, so does that.
Now instead it is showing “heating” only when its own temperature is below threshold.
Do you see a similar behaviour?
Is the issue on netatmo or HA side?
See how now is never “green” when other thermostats (below) are actually requiring hot water (time frame is the same):
