Netatmo was working fine (0.19.4) but after the update to 0.20.1 no sensor entries are displayed.
Had for a short time the 0.20.0 installed but not sure if the issue was already present in that version.
From the logs it looks like my two Netatmo modules are not found:
16-05-23 14:37:22 homeassistant.components.sensor.netatmo: Module name: "Inside" not found
16-05-23 14:37:22 homeassistant.components.sensor.netatmo: Module name: "Outside" not found
Since I changed nothing and the component Netatmo did not change as well, I suppose this is bug?
