As far as i understand it, it is now required to have your Home Assistant instance exposed to the internet if you want to use the webhooks of the Netatmo integration. Which is further required if you want to be able to automate on movement detection of a person on a Presence camera. Please correct me if I’m wrong.
However, it also seems that only port 80 and 443 is supported… My problem is that i already have a webserver running here, which listens on port 80 and 443 hence i cannot use those ports to expose my instance. Does this mean that i cannot use webhooks with my Netatmo camera?
