h4nc
July 18, 2019, 8:12pm
1
Before 0.96 we were able to enable different sensors of each module.
Now it looks liek we can only enable the whole module with all it’s sensors.
So before something like:
- platform: netatmo
station: wheaterstation
modules:
livingroom:
- temperature
- humidity
- co2
- noise
- bedroom:
- temperature
- humidity
- co2
- battery_vp
And now:
- platform: netatmo
modules:
- livingroom
- bedroom
Is there still a way to only enable specific sensors?
I am also wondering about this.
The release notes mentioned fixing some things in the Netatmo module - but this feels like it breaks a whole lot with no mention.
At least it broke my previously working Netatmo config.
cgtobi
(Tobi)
July 19, 2019, 11:10am
3
Yes, there is a breaking change in 0.96. Unfortunately it was not mentioned in the release notes. I’ll fix this right away.
Implement ADR0003 for Netatmo sensor (@cgtobi - #24944 ) (netatmo docs ) (breaking change)
No there is no way to only use a subset of attributes since it has been agreed on removing that functionality. See: architecture/adr/0003-monitor-condition-and-data-selectors.md at 68f3b33b517121030aa6e5e0c471e4b966ac7105 · home-assistant/architecture · GitHub
h4nc
July 19, 2019, 11:24am
4
Thanks for clearing that up.
In fact with the new way I found out that I can also have the percentage data of the batteries.
El_Viejo
(Javier Elorriaga)
July 19, 2019, 11:30am
5
It is necessary to recognize the effort of the development team.
Version 0.96.1 has corrected several deficiencies, but, in the weather station, it does not load the entities of maximum and minimum temperatures.
Does it only happen to me? or do more users have this problem.
Thanks for the effort.
cgtobi
(Tobi)
July 19, 2019, 11:50am
6
There is also an issue on that topic. https://github.com/home-assistant/home-assistant/issues/25289
And I already fixed it upstream. I am just waiting for a new release of pyatmo. I am sorry for any inconvenience that may have caused.
El_Viejo
(Javier Elorriaga)
July 19, 2019, 2:12pm
7
Thank you very much for your information. It is not a major problem and I look forward to the solution.
El_Viejo
(Javier Elorriaga)
July 25, 2019, 8:21am
9
Maximum and minimum temperature solved in version 0.96.4
Thank you very much for the effort.
