Greetings! I had a working Pi4 HA install, but it was running on SD card, and wanted to migrate. I also happened to have an older Lenovo laptop that was still in great shape, but not great for current workloads, so I installed HA on it and restored my backup on it
After a little bit of moving some dongles around, it’s working perfectly fine, all except the Netgear integration. It kept ‘failing to load’ with no real way to diagnose it. I was able to pull this one line from the diagnostic log that mentioned it:
2025-03-28 12:10:54.462 ERROR (SyncWorker_6) [pynetgear.router] Unauthorized response, re-login failed
There didn’t appear to be a way to re-authorize the login. I’ve confirmed I can log in from any PC on the network, and then I’ve deleted the Netgear intergration, only to have it ‘find new device’ right away.
If I type in my username (admin) and password (custom to my house) it says “Failed to get info from router” in red. If I mistype the username or password, I get a different error about credentials, so I know the username / password are correct.
This appears to be the same bug listed here on github: Netgear - “Failed to get info from router” #122777, but it was closed for being ‘stale’. What did that person do to resolve ti?
What am I to do? How do I resolve this problem with the Netgear intergration?
