Network configuration settings not working
I’m trying to install HassIO on a Raspberry Pi 3B+ using the 32bit installer from here. I’m following the instructions from here. I’ve done this before without incident but scratched the install to start another one in a docker container in a HyperV virtual machine (Ubuntu). I’m now wanting to migrate back over to the Pi and HASSIO. I’m using Balena etcher to image the 32GB SD card, and that part seems to work fine. I copy over the CONFIG/network/my-network file to the boot partition on the SD card, then unplug the SD card from my computer and insert into the Pi. The HassIO boot process kicks in, but it never connects to the network. I eventually shut it down and when I insert the SD card back into my PC, the CONFIG folder with the network settings has disappeared. I don’t think it’s a HassIO problem necessarily, but I figured maybe because it’s kind of a unique process that others here have used, maybe someone would have some insight on what the problem is.
