Network error but it shows items on network
Hi, here is a bit of an odd one. I am very new to all this and I have just installed Home assistant on a Raspberry Pi4. Home assistant was installed on the micro SD and i logged in using http://homeassistant.local:8123/ and all works great. The setup screen appears and goes through the process but it comes up with an network error and states “can not get network information”. The weird thing is that it shows all the devices that are connected to the network. I have added the HIVE that was detected and the thermostat and all the devices are shown and the HIVE HUB is connected, but if I try and TOGGLE on/off a light that is listed in overview i get the error “Failed to perform the action switch/turn_off. unknown”. Have i not done something correctly?
