Network installation problem
I installed HA on a virtual machine according to the explanation on the website (Windows - Home Assistant), but I ran into basic problems in setting up the communication, my network receives the address range of 10.0.0.X, for the machine’s network card Virtually I gave an address
ip 10.0.0.50
sub 255.255.255.0
DG 10.0.0138
DNS 8.8.8.8
dns 1.1.1.1
After installing the machine, it received an address automatically, but then I was unable to reach any device I have on the network and the cell phone/tablet also failed to connect to HA in the application,( getting white screen)
Should I set something specific on this screen or leave it on automatic? , what about port forwarding to which address and which ports should be opened? I installed Duckdns and configured it, I understood that it should give me connection from outside the house?
what is External/Internal URL when trying to install Samsung Smart things ?
best regards!
Maybe tell what VM Manager you are using, and how did you set it up.
Oracel VM virtualbox .
Network > Adapter 1 . Choose Bridged Adapter and choose your network adapter.
look like i fix it somehow .
but still have problem with Smart Things
getting this msg
smart6
Setup remote access via a domain name secured with SSL.
