Network problem or DNS-Problem
I’ve had a configuration problem for over a week where I can’t get any further.
I am using the Home Assistant in Docker.
The system is no longer accessible from the outside, not even the other services running on the Raspberry (behind a Fritzbox with port sharing). Also, some apps in the HA no longer work because they no longer have a connection to the Internet, even the current update from 2024.1.3 to 2024.1.5 cannot be carried out.
Outgoing pings are no longer attempted via eth0 but via a virtual interface ( veth*).
If I restart the system, everything works, but only for a few minutes.
I can provide screenshots or more information at a later date.
I hope that someone can help me.
What changed or what happened immediately before it started.
I learned from a very good infrastructure engineer 20 years ago ‘all issues are name resolution (DNS) issues until proven otherwise.’
Still true. So what changed.
If I knew, I wouldn’t be able to answer that exactly.
I have updated the system from Raspbian Bullseye to Bookworm.
I wonder why the pings first go out correctly from eth0 and then later from veth. This is not clear to me at all.
Also why I can always reach the system internally, but not from outside (or only in the first few minutes).
A firewall is not running.
Check your routes and make sure you NetworkManager, or whatever you use for managing your network interfaces, are correctly configured and working properly.
Are you taking updates? I’d so what happens if you roll back to the version you had before it stopped?
Maybe not a firewall but from a network perspective - the same thing.
If you can’t pinpoint an update that happened in that time then I suggest drawing yourself a diagram with your subnets and draw your comms back and forth through your expected paths. Think through each hop. If I want to get to the internet from HA to do this what’s my path? And verify every hop with what the config is.
My bet is something at the Fritzbox
I was able to narrow down the cause:
As soon as I stop the service “hassio-supervisor.service” I have full network functionality again.
The cross-check by starting the service returned the problems.
Let’s see how I get on with it.
Read about the recent problems with the latest docker upgrade and supervised ?
