Hi
Where I can I find this menu?
Supervisor|System|Host, click on “change” next to the IP address.
It seems I can’t. I need to install the adguard addon but I am stuck in step 1.
- Ensure your Home Assistant device has a static IP and static external DNS servers!
Probably to do with your unsupported / unhealthy installation.
But you should nevertheless be able to set a static IP from ubuntu, or by static DHCP reservation.
Well I don’t know much for networks.(either)
I have a static ip for HA through the router. Is it the same?
Yes that should be fine. That is what I meant by static dhcp reservation.
