Neverin – Home Assistant Integration
An unofficial Home Assistant integration for Neverin, providing access to weather station data from over 1,000 stations across Croatia and the region.
The integration uses Neverin weather data and allows easy station selection directly from the Home Assistant UI.
Features
Fetches available Neverin weather stations
Easy UI-based setup (Config Flow)
Native Home Assistant integration
Installation (HACS)
or
Add Custom Repository to HACS
- Open HACS
- Go to Integrations
- Click ⋮ (top right) → Custom repositories
- Add:
- Repository:
https://github.com/potrgani/neverin - Category:
Integration
- Repository:
- Click Add
Install the Integration
- In HACS → Integrations
- Search for Neverin
- Click Download
- Restart Home Assistant
Configuration
- Go to Settings → Devices & Services
- Click Add Integration
- Select your desired Neverin station from the list
- Save the configuration
The integration is now ready to use!
Notes
- Only active stations are shown
- Data availability depends on the Neverin API
Issues & Contributions
If you encounter a bug or have a suggestion:
- Open a GitHub Issue at
https://github.com/potrgani/neverin/issues - Or submit a Pull Request
Contributions are welcome ![]()
Disclaimer
This integration is not an official Neverin product.
It is a community-developed project.
