Looks like something is not working with the “quick tunnel” option.
I’e been trying multiple times but I always end up with the auth URL but never nothing relating to quick tunnels.
My conf file is :
> external_hostname: ''
> tunnel_name: ''
> additional_hosts: []
> quick_tunnel: true
Actually “quick_tunnel: true” switch back to the end of the conf each timeI hit save.
Log showing :
Add-on: Cloudflared
Use a Cloudflared tunnel (formerly Argo Tunnel) to remotely connect to Home Assistant without opening any ports
Add-on version: 0.2.4
You are running the latest version of this add-on.
System: Home Assistant OS 7.0 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.12.10
Home Assistant Supervisor: 2022.01.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] cloudflared-config.sh: executing...
[22:08:44] INFO: Checking for existing certificate...
[22:08:44] NOTICE: No certificate found
[22:08:44] INFO: Creating new certificate...
[22:08:44] NOTICE: Please follow the Cloudflare Auth-Steps:
Please open the following URL and log in with your Cloudflare account:
https://dash.cloudflare.com/argotunnel?callback=https%3A%2F%2Flogin.cloudflareaccess.org%2FUbz***************
Leave cloudflared running to download the cert automatically.
2022-02-01T02:09:37Z INF Waiting for login...
2022-02-01T02:10:30Z INF Waiting for login...
2022-02-01T02:11:23Z INF Waiting for login...
2022-02-01T02:12:16Z INF Waiting for login...
2022-02-01T02:13:10Z INF Waiting for login...
2022-02-01T02:14:03Z INF Waiting for login...
2022-02-01T02:14:56Z INF Waiting for login...
2022-02-01T02:15:49Z INF Waiting for login...
2022-02-01T02:16:42Z INF Waiting for login...
2022-02-01T02:17:35Z INF Waiting for login...
Failed to write the certificate due to the following error:
Failed to fetch resource
Your browser will download the certificate instead. You will have to manually
copy it to the following path:
/root/.cloudflared/cert.pem
[cont-init.d] cloudflared-config.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
And I have this in server logs :
Option 'quick_tunnel' does not exist in the schema for Cloudflared
Any idea why it’s not playing with the trycloudfare thing ?
Thanks.
