Hi there,
I already posted on GitHub, but I’m not sure how often issues are checked there. So I post the same issue here again:
First of all thanks for this great home assistant addon! I have a Baier easywave blind controlled via a remote with three buttons (up reporting as A, down reporting as B and stop reporting as C).
I successfully have paired the usb stick and I can control the blind via your addon in home assistant.
I have one problem though:
On the Baier remote only the up and down buttons work, not the stop button. When I close the blinds with the remote, I press the down button (B). To stop it half way I have to press the up button (A). To open it again (form half closed) I have to press the up button (A) again. Button C doesn’t do anything.
So in home assistant, if I want to close the blind half way (I am pressing down arrow (sending B) and then pressing up arrow (sending A) to stop). However now I cannot open the blind again (the up arrow is grayed out). I can only close it all the way. Once it is completely closed, I can then open the blind again with the up arrow (not grayed out anymore). I hope you understand what I mean.
Now my question:
Is there any way to fix this? Meaning not graying out any arrows after it is pressed once?
Best
Daniel
