I upgraded to 0.87, removed my “Aeotec Limited ZWA001 LED Bulb 6 Multi-White” from the Z-Wave network, and then added it securely again. After a restart I can use the bulb for on/off and brightness, and the color slider shows, but moving the slider does not result in any color temperature change. I’d love to help with this but I’m not sure how to. I am not seeing anything unusual in the logs. In config options for this node, I can set the desired “warm white” and “cold white” temperatures; It’s definitely recognized as the “correct” bulb from the OZW config files. Note that after I change the temp slider, it is reset to the warm position if I then make another change, like the brightness.
Here’s an example of setting the temp slider to the left all the way, with the bulb already on:
2019-02-11 18:03:54.419 Info, Node014, Value::Set - COMMAND_CLASS_COLOR - Color - 0 - 1 - #00000000ff
2019-02-11 18:03:54.420 Info, Node014, Color::SetValue - Setting Color value
2019-02-11 18:03:54.420 Detail, Node014, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_COLOR
2019-02-11 18:03:54.421 Detail, Node014, Queuing (Send) ColorCmd_Set (Node=14): 0x01, 0x15, 0x00, 0x13, 0x0e, 0x0e, 0x33, 0x05, 0x05, 0x02, 0x00, 0x03, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0x25, 0x27, 0xcc
2019-02-11 18:03:54.421 Detail, Node014, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_COLOR
2019-02-11 18:03:54.421 Detail, Node014, Queuing (Send) ColorCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x33, 0x03, 0x00, 0x25, 0x28, 0xd6
2019-02-11 18:03:54.421 Detail, Node014, Queuing (Send) ColorCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x33, 0x03, 0x01, 0x25, 0x29, 0xd6
2019-02-11 18:03:54.422 Detail,
2019-02-11 18:03:54.422 Info, Node014, Processing (Send) Nonce Request message (Callback ID=0x27, Expected Reply=0x00)
2019-02-11 18:03:54.422 Info, Node014, Sending (Send) message (Callback ID=0x27, Expected Reply=0x00) - Nonce_Get(ColorCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-02-11 18:03:54.422 Info, Node014, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2019-02-11 18:03:54.423 Detail, Node014, Refreshed Value: old value=255, new value=255, type=byte
2019-02-11 18:03:54.423 Detail, Node014, Changes to this value are not verified
2019-02-11 18:03:54.423 Detail, Node014, Notification: ValueChanged
2019-02-11 18:03:54.433 Info, Node014, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2019-02-11 18:03:54.433 Info, Node014, SwitchMultilevel::Set - Setting to level 255
2019-02-11 18:03:54.433 Info, Node014, Duration: Default
2019-02-11 18:03:54.433 Detail, Node014, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2019-02-11 18:03:54.434 Detail, Node014, Queuing (Send) SwitchMultilevelCmd_Set (Node=14): 0x01, 0x0b, 0x00, 0x13, 0x0e, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x2a, 0xc5
2019-02-11 18:03:54.434 Detail, Node014, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2019-02-11 18:03:54.434 Detail, Node014, Queuing (Send) SwitchMultilevelCmd_Get (Node=14): 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x26, 0x02, 0x25, 0x2b, 0xc3
2019-02-11 18:03:54.439 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.439 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.450 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2019-02-11 18:03:54.452 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-02-11 18:03:54.452 Info, Node014, Request RTT 29 Average Request RTT 63
2019-02-11 18:03:54.467 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0x11, 0x65, 0x10, 0x49, 0x57, 0xb2, 0x0c, 0xba, 0x89
2019-02-11 18:03:54.468 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.468 Info, Node014, Sending (Send) message (Callback ID=0x2c, Expected Reply=0x00) - ColorCmd_Set (Node=14): 0x01, 0x15, 0x00, 0x13, 0x0e, 0x0e, 0x33, 0x05, 0x05, 0x02, 0x00, 0x03, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0x25, 0x2c, 0xc7
2019-02-11 18:03:54.482 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.483 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.503 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x02, 0xc5
2019-02-11 18:03:54.503 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2019-02-11 18:03:54.503 Info, Node014, Request RTT 80 Average Request RTT 71
2019-02-11 18:03:54.503 Detail, Expected callbackId was received
2019-02-11 18:03:54.503 Detail, Message transaction complete
2019-02-11 18:03:54.503 Detail, Node014, Removing current message
2019-02-11 18:03:54.503 Info, Node014, Processing (Send) Nonce Request message (Callback ID=0x28, Expected Reply=0x04)
2019-02-11 18:03:54.503 Info, Node014, Sending (Send) message (Callback ID=0x28, Expected Reply=0x04) - Nonce_Get(ColorCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-02-11 18:03:54.513 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.514 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.530 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2019-02-11 18:03:54.530 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-02-11 18:03:54.530 Info, Node014, Request RTT 26 Average Request RTT 48
2019-02-11 18:03:54.547 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0x5a, 0xc0, 0x06, 0x0f, 0x9f, 0xa9, 0x5c, 0xba, 0xb4
2019-02-11 18:03:54.547 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.547 Info, Node014, Sending (Send) message (Callback ID=0x2d, Expected Reply=0x04) - ColorCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x33, 0x03, 0x00, 0x25, 0x2d, 0xd3
2019-02-11 18:03:54.562 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.562 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.579 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x02, 0xc4
2019-02-11 18:03:54.580 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2019-02-11 18:03:54.580 Info, Node014, Request RTT 76 Average Request RTT 62
2019-02-11 18:03:54.580 Detail, Expected callbackId was received
2019-02-11 18:03:54.598 Detail, Node014, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0e, 0x02, 0x98, 0x40, 0x27
2019-02-11 18:03:54.598 Info, Node014, Received SecurityCmd_NonceGet from node 14
2019-02-11 18:03:54.598 Info, NONCES: 0xbb, 0x30, 0x34, 0xf7, 0x3c, 0x73, 0xd0, 0xe5
2019-02-11 18:03:54.598 Info, NONCES: 0xa5, 0x1b, 0xeb, 0x3d, 0x2c, 0x68, 0x3c, 0x3f
2019-02-11 18:03:54.598 Info, NONCES: 0x4f, 0xd3, 0xe3, 0x0d, 0x0d, 0xe0, 0x94, 0xc8
2019-02-11 18:03:54.598 Info, NONCES: 0xac, 0x1e, 0x1f, 0xd8, 0x87, 0x5b, 0x18, 0x0c
2019-02-11 18:03:54.598 Info, NONCES: 0xfa, 0x92, 0x22, 0x08, 0x73, 0xb7, 0xd0, 0x84
2019-02-11 18:03:54.598 Info, NONCES: 0x24, 0xc0, 0xa6, 0xaa, 0x1b, 0xbe, 0xb7, 0xa9
2019-02-11 18:03:54.598 Info, NONCES: 0x27, 0x33, 0xa2, 0x83, 0x20, 0x8e, 0x03, 0xcc
2019-02-11 18:03:54.598 Info, NONCES: 0xa8, 0x32, 0x4b, 0x06, 0x98, 0x10, 0x7d, 0xfe
2019-02-11 18:03:54.598 Info, Node014, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0e, 0x0a, 0x98, 0x80, 0x27, 0x33, 0xa2, 0x83, 0x20, 0x8e, 0x03, 0xcc, 0x05, 0x01, 0xb1:
2019-02-11 18:03:54.610 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.610 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.626 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2019-02-11 18:03:54.627 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-02-11 18:03:54.627 Info, Node014, Request RTT 123 Average Request RTT 92
2019-02-11 18:03:54.650 Detail, Node014, Received: 0x01, 0x1e, 0x00, 0x04, 0x00, 0x0e, 0x18, 0x98, 0x81, 0x98, 0x13, 0xa5, 0x0d, 0xfc, 0x21, 0x31, 0x22, 0x50, 0x1a, 0xaf, 0xfb, 0xb5, 0x27, 0x27, 0x48, 0x49, 0x34, 0x93, 0x0c, 0x01, 0x0f, 0x08
2019-02-11 18:03:54.650 Info, Raw: 0x98, 0x81, 0x98, 0x13, 0xa5, 0x0d, 0xfc, 0x21, 0x31, 0x22, 0x50, 0x1a, 0xaf, 0xfb, 0xb5, 0x27, 0x27, 0x48, 0x49, 0x34, 0x93, 0x0c, 0x01, 0x0f, 0x08
2019-02-11 18:03:54.650 Detail, Node014, Decrypted Packet: 0x00, 0x33, 0x04, 0x00, 0xff
2019-02-11 18:03:54.650 Info, Node014, Response RTT 146 Average Response RTT 214
2019-02-11 18:03:54.650 Detail, Node014, Expected reply and command class was received
2019-02-11 18:03:54.650 Detail, Node014, Message transaction complete
2019-02-11 18:03:54.650 Detail, Node014, Removing current message
2019-02-11 18:03:54.651 Detail,
2019-02-11 18:03:54.651 Info, Node014, Processing (Send) Nonce Request message (Callback ID=0x29, Expected Reply=0x04)
2019-02-11 18:03:54.651 Info, Node014, Sending (Send) message (Callback ID=0x29, Expected Reply=0x04) - Nonce_Get(ColorCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-02-11 18:03:54.660 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.661 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.678 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2019-02-11 18:03:54.678 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-02-11 18:03:54.678 Info, Node014, Request RTT 27 Average Request RTT 59
2019-02-11 18:03:54.696 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0xcd, 0x00, 0x8e, 0x7c, 0x48, 0x25, 0x9e, 0xe7, 0xdc
2019-02-11 18:03:54.697 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.697 Info, Node014, Sending (Send) message (Callback ID=0x2e, Expected Reply=0x04) - ColorCmd_Get (Node=14): 0x01, 0x0a, 0x00, 0x13, 0x0e, 0x03, 0x33, 0x03, 0x01, 0x25, 0x2e, 0xd1
2019-02-11 18:03:54.711 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.712 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.729 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x2e, 0x00, 0x00, 0x02, 0xc7
2019-02-11 18:03:54.729 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x2e received (expected 0x2e)
2019-02-11 18:03:54.729 Info, Node014, Request RTT 78 Average Request RTT 68
2019-02-11 18:03:54.729 Detail, Expected callbackId was received
2019-02-11 18:03:54.748 Detail, Node014, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0e, 0x02, 0x98, 0x40, 0x27
2019-02-11 18:03:54.748 Info, Node014, Received SecurityCmd_NonceGet from node 14
2019-02-11 18:03:54.748 Info, NONCES: 0xbb, 0x30, 0x34, 0xf7, 0x3c, 0x73, 0xd0, 0xe5
2019-02-11 18:03:54.748 Info, NONCES: 0xa5, 0x1b, 0xeb, 0x3d, 0x2c, 0x68, 0x3c, 0x3f
2019-02-11 18:03:54.748 Info, NONCES: 0x4f, 0xd3, 0xe3, 0x0d, 0x0d, 0xe0, 0x94, 0xc8
2019-02-11 18:03:54.749 Info, NONCES: 0xac, 0x1e, 0x1f, 0xd8, 0x87, 0x5b, 0x18, 0x0c
2019-02-11 18:03:54.749 Info, NONCES: 0xfa, 0x92, 0x22, 0x08, 0x73, 0xb7, 0xd0, 0x84
2019-02-11 18:03:54.749 Info, NONCES: 0x24, 0xc0, 0xa6, 0xaa, 0x1b, 0xbe, 0xb7, 0xa9
2019-02-11 18:03:54.749 Info, NONCES: 0x27, 0x33, 0xa2, 0x83, 0x20, 0x8e, 0x03, 0xcc
2019-02-11 18:03:54.749 Info, NONCES: 0xc5, 0xdf, 0x4e, 0x7f, 0xd7, 0xcd, 0xc7, 0x24
2019-02-11 18:03:54.749 Info, Node014, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0e, 0x0a, 0x98, 0x80, 0xc5, 0xdf, 0x4e, 0x7f, 0xd7, 0xcd, 0xc7, 0x24, 0x05, 0x01, 0x37:
2019-02-11 18:03:54.761 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.761 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.776 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2019-02-11 18:03:54.777 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-02-11 18:03:54.777 Info, Node014, Request RTT 125 Average Request RTT 96
2019-02-11 18:03:54.800 Detail, Node014, Received: 0x01, 0x1e, 0x00, 0x04, 0x00, 0x0e, 0x18, 0x98, 0x81, 0x16, 0xe1, 0x74, 0x20, 0xd6, 0x9a, 0x58, 0x44, 0x56, 0xc6, 0x82, 0x99, 0xf5, 0xc5, 0x15, 0x3f, 0xb2, 0xd5, 0x38, 0xb2, 0xcb, 0xa3, 0x0d
2019-02-11 18:03:54.800 Info, Raw: 0x98, 0x81, 0x16, 0xe1, 0x74, 0x20, 0xd6, 0x9a, 0x58, 0x44, 0x56, 0xc6, 0x82, 0x99, 0xf5, 0xc5, 0x15, 0x3f, 0xb2, 0xd5, 0x38, 0xb2, 0xcb, 0xa3, 0x0d
2019-02-11 18:03:54.801 Detail, Node014, Decrypted Packet: 0x00, 0x33, 0x04, 0x01, 0x00
2019-02-11 18:03:54.801 Info, Node014, Response RTT 149 Average Response RTT 181
2019-02-11 18:03:54.801 Info, Node014, Received a updated Color from Device: #000000FF00
2019-02-11 18:03:54.801 Detail, Node014, Refreshed Value: old value=#000000FF00, new value=#000000FF00, type=string
2019-02-11 18:03:54.801 Detail, Node014, Changes to this value are not verified
2019-02-11 18:03:54.801 Detail, Node014, Refreshed Value: old value=2, new value=2, type=list
2019-02-11 18:03:54.801 Detail, Node014, Expected reply and command class was received
2019-02-11 18:03:54.801 Detail, Node014, Message transaction complete
2019-02-11 18:03:54.801 Detail, Node014, Removing current message
2019-02-11 18:03:54.801 Detail, Node014, Notification: ValueChanged
2019-02-11 18:03:54.806 Detail, Node014, Notification: ValueChanged
2019-02-11 18:03:54.809 Detail,
2019-02-11 18:03:54.809 Info, Node014, Processing (Send) Nonce Request message (Callback ID=0x2a, Expected Reply=0x13)
2019-02-11 18:03:54.809 Info, Node014, Sending (Send) message (Callback ID=0x2a, Expected Reply=0x13) - Nonce_Get(SwitchMultilevelCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-02-11 18:03:54.820 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.820 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.837 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0xeb
2019-02-11 18:03:54.837 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-02-11 18:03:54.838 Info, Node014, Request RTT 28 Average Request RTT 62
2019-02-11 18:03:54.854 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0x5a, 0xcb, 0xac, 0xb3, 0xb3, 0x5e, 0x3f, 0xd4, 0x7f
2019-02-11 18:03:54.854 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.854 Info, Node014, Sending (Send) message (Callback ID=0x2f, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=14): 0x01, 0x0b, 0x00, 0x13, 0x0e, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x2f, 0xc0
2019-02-11 18:03:54.868 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.868 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.885 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x2f, 0x00, 0x00, 0x03, 0xc7
2019-02-11 18:03:54.885 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x2f received (expected 0x2f)
2019-02-11 18:03:54.885 Info, Node014, Request RTT 76 Average Request RTT 69
2019-02-11 18:03:54.885 Detail, Expected callbackId was received
2019-02-11 18:03:54.885 Detail, Expected reply was received
2019-02-11 18:03:54.885 Detail, Message transaction complete
2019-02-11 18:03:54.886 Detail,
2019-02-11 18:03:54.886 Detail, Node014, Removing current message
2019-02-11 18:03:54.886 Info, Node014, Processing (Send) Nonce Request message (Callback ID=0x2b, Expected Reply=0x04)
2019-02-11 18:03:54.886 Info, Node014, Sending (Send) message (Callback ID=0x2b, Expected Reply=0x04) - Nonce_Get(SwitchMultilevelCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-02-11 18:03:54.897 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.897 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.904 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0x5a, 0xcb, 0xac, 0xb3, 0xb3, 0x5e, 0x3f, 0xd4, 0x7f
2019-02-11 18:03:54.904 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.905 Info, Node014, Sending (Send) message (Callback ID=0x30, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=14): 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x26, 0x02, 0x25, 0x30, 0xd8
2019-02-11 18:03:54.919 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.919 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:54.929 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x30, 0x00, 0x00, 0x02, 0xd9
2019-02-11 18:03:54.931 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x30 received (expected 0x30)
2019-02-11 18:03:54.931 Info, Node014, Request RTT 45 Average Request RTT 57
2019-02-11 18:03:54.931 Detail, Expected callbackId was received
2019-02-11 18:03:54.985 Detail, Node014, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x0e, 0x0a, 0x98, 0x80, 0x5c, 0x5f, 0x5c, 0x20, 0xba, 0x29, 0x72, 0x0d, 0x64
2019-02-11 18:03:54.985 Info, Node014, Received SecurityCmd_NonceReport from node 14
2019-02-11 18:03:54.985 Info, Node014, Sending (Send) message (Callback ID=0x31, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=14): 0x01, 0x09, 0x00, 0x13, 0x0e, 0x02, 0x26, 0x02, 0x25, 0x31, 0xd9
2019-02-11 18:03:54.999 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:54.999 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:55.035 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x31, 0x00, 0x00, 0x05, 0xdf
2019-02-11 18:03:55.035 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x31 received (expected 0x31)
2019-02-11 18:03:55.035 Info, Node014, Request RTT 150 Average Request RTT 103
2019-02-11 18:03:55.035 Detail, Expected callbackId was received
2019-02-11 18:03:55.065 Detail, Node014, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0e, 0x02, 0x98, 0x40, 0x27
2019-02-11 18:03:55.065 Info, Node014, Received SecurityCmd_NonceGet from node 14
2019-02-11 18:03:55.066 Info, NONCES: 0xb0, 0x7e, 0x68, 0x87, 0x4c, 0x30, 0xab, 0x33
2019-02-11 18:03:55.066 Info, NONCES: 0xa5, 0x1b, 0xeb, 0x3d, 0x2c, 0x68, 0x3c, 0x3f
2019-02-11 18:03:55.066 Info, NONCES: 0x4f, 0xd3, 0xe3, 0x0d, 0x0d, 0xe0, 0x94, 0xc8
2019-02-11 18:03:55.066 Info, NONCES: 0xac, 0x1e, 0x1f, 0xd8, 0x87, 0x5b, 0x18, 0x0c
2019-02-11 18:03:55.066 Info, NONCES: 0xfa, 0x92, 0x22, 0x08, 0x73, 0xb7, 0xd0, 0x84
2019-02-11 18:03:55.066 Info, NONCES: 0x24, 0xc0, 0xa6, 0xaa, 0x1b, 0xbe, 0xb7, 0xa9
2019-02-11 18:03:55.066 Info, NONCES: 0x27, 0x33, 0xa2, 0x83, 0x20, 0x8e, 0x03, 0xcc
2019-02-11 18:03:55.066 Info, NONCES: 0xc5, 0xdf, 0x4e, 0x7f, 0xd7, 0xcd, 0xc7, 0x24
2019-02-11 18:03:55.066 Info, Node014, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0e, 0x0a, 0x98, 0x80, 0xb0, 0x7e, 0x68, 0x87, 0x4c, 0x30, 0xab, 0x33, 0x05, 0x01, 0x20:
2019-02-11 18:03:55.078 Detail, Node014, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-11 18:03:55.079 Detail, Node014, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-11 18:03:55.100 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2019-02-11 18:03:55.101 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-02-11 18:03:55.101 Info, Node014, Request RTT 215 Average Request RTT 159
2019-02-11 18:03:55.162 Detail, Node014, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x09, 0xe3
2019-02-11 18:03:55.162 Detail, Node014, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2019-02-11 18:03:55.162 Info, Node014, Request RTT 276 Average Request RTT 217
2019-02-11 18:03:55.178 Detail, Node014, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x0e, 0x17, 0x98, 0x81, 0xb6, 0xe7, 0x2a, 0x5b, 0x0a, 0x07, 0xf5, 0x53, 0xb8, 0x62, 0x3e, 0xc4, 0xb0, 0x3a, 0x48, 0xcb, 0x11, 0xe0, 0x1a, 0x76, 0x38, 0xe1
2019-02-11 18:03:55.178 Info, Raw: 0x98, 0x81, 0xb6, 0xe7, 0x2a, 0x5b, 0x0a, 0x07, 0xf5, 0x53, 0xb8, 0x62, 0x3e, 0xc4, 0xb0, 0x3a, 0x48, 0xcb, 0x11, 0xe0, 0x1a, 0x76, 0x38, 0xe1
2019-02-11 18:03:55.178 Detail, Node014, Decrypted Packet: 0x00, 0x26, 0x03, 0x1c
2019-02-11 18:03:55.179 Info, Node014, Response RTT 293 Average Response RTT 237
2019-02-11 18:03:55.179 Info, Node014, Received SwitchMultiLevel report: level=28
2019-02-11 18:03:55.179 Detail, Node014, Refreshed Value: old value=28, new value=28, type=byte
2019-02-11 18:03:55.179 Detail, Node014, Changes to this value are not verified
2019-02-11 18:03:55.179 Detail, Node014, Expected reply and command class was received
2019-02-11 18:03:55.179 Detail, Node014, Message transaction complete
2019-02-11 18:03:55.179 Detail, Node014, Removing current message
2019-02-11 18:03:55.179 Detail, Node014, Notification: ValueChanged
Another edit: I confirmed the workaround is being detected and enabled on my system:
