tom_l
August 23, 2018, 3:24am
1
I enabled the new auth system on my Hassio (pi) last night and then couldn’t work out how to configure it as this page: https://developers.home-assistant.io/blog/2018/07/02/trying-new-auth.html is pretty sparse.
“If you are using Hass.io , you must enable legacy API password support.” Great. How do I do that?
“This rest of the instructions are no longer necessary in Home Assistant 0.74 or later.” Fine. There’s nothing to configure then?
So I gave up and commented out the the following in my configuration.yaml:
homeassistant:
# auth_providers:
# - type: homeassistant
Then I restarted Hassio.
Unfortunately now Owntracks (HTTP) is reporting 403 errors when trying to connect. Is there any way to fix this?
awarecan
(Jason Hu)
August 23, 2018, 3:58am
2
# Example configuration.yaml entry
homeassistant:
auth_providers:
# Uncomment next line if you want to enable legacy API password support
# - type: legacy_api_password
Did you saw “Uncomment next line if you want to enable legacy API password support”?
tom_l
August 23, 2018, 5:31am
3
No, I overlooked that. Sorry. Should I commet out - type: homeassistant
as well as un-commenting - type: legacy_api_password
Edit:
I tried with and without - type: homeassistant
in both cases I get the following warning and Owntracks is still not connecting:
Please change to use bearer token access /api/error/all
This is my current config:
homeassistant:
auth_providers:
# - type: trusted_networks
tom_l
August 24, 2018, 12:22am
4
Solution: IP ban had blocked the phone Ownracks was running on.
Also I finally see the new login page after a few HA restarts and forcing a web browser cache refresh.
