I am trying to use new bk72xx_ble_tracker but I can’t get it to work stable
after this logline [14:41:24.028][D][wifi:2506]: Roam scan (-57 dBm, attempt 1/3)
the devices get’s unresponsive every time.
Could be but I would expect default values from example to work, at least alone. Could be bug though.
You are really shy with providing info.
What device you have, how it’s powered and logged? What else do you have on your config? What else do you get on logs?
the device is powered via main power (230V).
It’s a ceiling light FAN combination,
light via pinout, fan works with Tuya DP’s
you do not want that full config.
I’m trying to connect the remotes which came with the Light/fan.
My log doesn’t show much,
a lot of tuya errors 16:17:21 [E] [tuya:529] Initialization failed at init_state 0 16:17:31 [D] [tuya:707] Setting datapoint 107 to 1 16:17:31 [W] [tuya:710] Setting unknown datapoint 107 16:17:31 [D] [tuya:707] Setting datapoint 105 to 6 16:17:31 [W] [tuya:710] Setting unknown datapoint 105 16:17:32 [E] [tuya:529] Initialization failed at init_state 0 16:17:33 [D] [tuya:707] Setting datapoint 107 to 0 16:17:33 [W] [tuya:710] Setting unknown datapoint 107 16:17:34 [E] [tuya:529] Initialization failed at init_state 0 16:17:35 [E] [tuya:529] Initialization failed at init_state 0
but I get them also without BLE,
and just the roam scan line,
after that nothing.
then it disconnects
logging via webinterface and ha addon, no uart,
I cannot connect that right now.
That kicks out any logs if wifi is gone.
Anyway, did you get any logs about BLE, which supposed to cause the problem?
Just pumping here, I don’t have any Tuya devices…
