I have tried pygattlib and pybatt and found neither of them very reliable. Whereas bluepy works like a charm, no problems yet.
I am new to the whole ecosystem, so let me say that this works very reliably but it probably needs some review/improvement/suggestions by someone who known what they’re doing (i.e. not me).
@seidler Hey, have you made any progress on the matter? I got myself a couple of Comet Blue / SilverCrest thermostats as well, with the sole intention of integrating them to HA – only to find out, you have already laid ground work.
create a new virtual Python Enviroment for the “blq-mqtt-bridge” with root user. The Component has to run with root priviledges for Bluetooth Access and scanning. (https://github.com/seidler2547/ble-mqtt-bridge). Afterwards start the ble-mqtt-bridge in that virtual python enviroment and let it run in the background.
Insert your Thermostats into the configuration.yaml of homeassistant:
platform: sygonix
devices:
Room01:
mac: ‘AA:BB:CC:DD:EE.FF’
pin: ‘123456’ (The default PIN is ‘000000’)
You can search via “hcitool lescan” as root user for Bluetooth MAC Addresses of the Thermostats.
Restart the homeassistant service… This should do the Trick if I remember correctly.
Thanks, yes, that’s roughly it. In the virtualenv I think you need to install paho-mqtt and bluepy?
mosquitto is needed because the built-in HA broker does not support wildcards correctly.
You can use a random PIN, if the thermostat is in factory default state, it has PIN 000000 so the component will try that and then change the PIN to the one defined in the HA config (but only when HA starts up). It will also set the date and time, so no need to bother with that.
yesterday i saw that in Germany LIDL will be offering Silvercrest thermostats for 25eu. These thermostats should be relabeled Homematic IP-thermostats.
I’d don’t know anything about integrating such thermostats in hassio but like to ask, if they will work with home assistant. Do i need the homematic base to get them working? Or is it possible to emulate this base with ha? Thanks in advance
Homematic IP is not bluetooth, so not related to this component. But I think Homematic is supported in Home Assistant, so should be able to make them work.
I have the same thermostat as dynamo30 (Comet Blue), I succesfully connected to the thermostat already via the cometblue script (https://github.com/im-0/cometblue) but I want to include it in Home Assistant
EDIT:
Solved it by learning basic yaml syntax
I added 2 spaces before “Bad:” and 4 spaces befor “mac:” and “pin:”
Don’t use PIN 000000 unless you would want other people to mess with your thermostats
If the current PIN is 000000 (factory default) then it will be set to the PIN you specify in the configuration when HA first communicates with the device.
Getting other values from the component into states is a bit of work because of the way HA works. You need to use template sensors:
I have installed hassio on the raspberry 3 with the sygonix.py located in the custom_components\climate folder.
unfortunately I not able to confirm that BT comunication is up ad running between HA and sygonix.
config validation done with possitive results so I assume that confiurations.yaml is fine.
current entries are
where can I check the status of the BT connection?
negative. I don’t start it, it’s a point.
I am puzzled how to “create a new virtual Python Enviroment for the “blq-mqtt-bridge” with root user” in hassio
I have a problem with this component. When I change temperature on thermostat it’s not updated in HA and value of current temperature is wrong - 64 degrees.
@Piwek,
I had +64 degrees (sometimes), most of the time right after I started the BLE-> mqtt - bridge, for just a short time only. I applied a ‘dirty’ fix in Sygonix.py to filter this out. (But I believe the real issue is with the BLE->mqtt-bridge…) Under line 191 (elif handle == UUID_TEMP:) I added:
if float(data[0])<128:
self.temperature = float(data[0])/2.0
If your measured temperature is constantly 64 degrees, above will not help obviously…
For the set value;
I noticed it takes some time before the set value is finally read back into HA, even 30 sec or longer. So whenever you change the set value, it could be reverted to previous set value withing a few seconds, you would think it doesn’t work. But eventually (30 sec later) HA received the updated value (read from thermostat) and the value you changed to is displayed. Actually, in a rear case it indeed does not adopt the set value at first attempt.
Another hint; HA 0.88.1 is now telling to change custom_components naming, should be “custom_components\sygonix\climate.py”, not “custom_components\climate\sygonix.py”.
