New deprecation warning in my logs since moving to HassOS
I have successfully moved my venv installation to HassOS 5.11 this morning. Everything is currently working fine but I now have this in my ha core logs that I did not have in my previous venv environment :
/usr/local/lib/python3.8/site-packages/aioharmony/hubconnector_websocket.py:88: DeprecationWarning: verify_ssl is deprecated, use ssl=False instead
  conn = aiohttp.TCPConnector(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:19: DeprecationWarning: Call to deprecated create function FileDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  DESCRIPTOR = _descriptor.FileDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:33: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _descriptor.EnumValueDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:37: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:41: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:27: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _SIGNATUREALGORITHM = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:60: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:64: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:54: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _HASHALGORITHM = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:90: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:84: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _CASTMESSAGE_PROTOCOLVERSION = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:108: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:112: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:102: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _CASTMESSAGE_PAYLOADTYPE = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:130: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:134: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:138: DeprecationWarning: Call to deprecated create function EnumValueDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:124: DeprecationWarning: Call to deprecated create function EnumDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _AUTHERROR_ERRORTYPE = _descriptor.EnumDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:158: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _descriptor.FieldDescriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:165: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:172: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:179: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:186: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:193: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:200: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:151: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _CASTMESSAGE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:233: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:240: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:247: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:226: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _AUTHCHALLENGE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:278: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:285: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:292: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:299: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:306: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:313: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:320: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:271: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _AUTHRESPONSE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:351: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:344: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _AUTHERROR = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:383: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:390: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:397: DeprecationWarning: Call to deprecated create function FieldDescriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
/usr/local/lib/python3.8/site-packages/pychromecast/cast_channel_pb2.py:376: DeprecationWarning: Call to deprecated create function Descriptor(). Note: Create unlinked descriptors is going to go away. Please use get/find descriptors from generated code or query the descriptor_pool.
  _DEVICEAUTHMESSAGE = _descriptor.Descriptor(
/usr/local/lib/python3.8/site-packages/hatasmota/utils.py:165: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.9 it will stop working
  if not isinstance(status, collections.Mapping):
I tried to search online but I did not find much about this. How can I solve them and remove them from my logs.
Thanks!
