I’m just checking if I configured something wrong or it’s a bug somewhere.
I use zwavejs2mqtt, 1.0.0-rc.1 version - in docker, which runs on a remote R-Pi and sends MQTT Messages to my main HA instance.
Everything was configured correctly, then overnight I lost power and my zwavejs2mqtt lost power and restarted.
What happened is that some of the devices became unavailable and new ones were created with “_2”, for example:
sensor.nodeid_19_notification_home_security_motion_sensor_status
- became unavailable
sensor.nodeid_19_notification_home_security_motion_sensor_status_2
- was created
I had MQTT Explorer running on a computer that didn’t loose power - I have UPS on it, and I can see a new discovery message was sent, but it’s identical to the previous ones, same topic was used, the MQTT Message is:
"value_template": "{{ {0: \"idle\",8: \"Motion detection\"}[value_json.value] | default(value_json.value) }}",
"icon": "mdi:motion-sensor",
"state_topic": "zwave/nodeID_19/113/0/Home_Security/Motion_sensor_status",
"json_attributes_topic": "zwave/nodeID_19/113/0/Home_Security/Motion_sensor_status",
"device": {
"identifiers": [
"zwavejs2mqtt_0xf4c9e959_node19"
"manufacturer": "AEON Labs",
"model": "Multisensor 6 (ZW100)",
"name": "nodeID_19",
"sw_version": "1.14"
"name": "nodeID_19_notification_home_security_motion_sensor_status",
"unique_id": "zwavejs2mqtt_0xf4c9e959_19-113-0-Home_Security-Motion_sensor_status"
I then later restarted the docker container, this issue was not seen again.
Did anybody else see this?
Thank you.
