New error in log after upgrade to Device Builder 2025.9.3?
This ili9xxx display had been running without errors before the update. The relevant section of the log is below:
[11:17:01.480][C][logger:273]: Logger:
[11:17:01.480][C][logger:273]:   Max Level: DEBUG
[11:17:01.480][C][logger:273]:   Initial Level: DEBUG
[11:17:01.482][C][logger:279]:   Log Baud Rate: 115200
[11:17:01.482][C][logger:279]:   Hardware UART: USB_CDC
[11:17:01.482][C][logger:286]:   Task Log Buffer Size: 768
[11:17:01.483][C][logger:291]:   Level for 'component': ERROR
[11:17:01.484][C][logger:291]:   Level for 'touchscreen': ERROR
[11:17:01.484][C][logger:291]:   Level for 'xpt2046': ERROR
[11:17:01.485][C][spi:067]: SPI bus:
[11:17:01.497][C][spi:068]:   CLK Pin: GPIO7
[11:17:01.498][C][spi:069]:   SDI Pin: GPIO9
[11:17:01.499][C][spi:070]:   SDO Pin: GPIO11
[11:17:01.502][C][spi:075]:   Using HW SPI: SPI2_HOST
[11:17:01.519][C][ili9xxx:089]: ili9xxx
[11:17:01.519][C][ili9xxx:089]:   Rotations: 0 °
[11:17:01.519][C][ili9xxx:089]:   Dimensions: 240px x 320px
[11:17:01.531][C][ili9xxx:090]:   Width Offset: 0
[11:17:01.531][C][ili9xxx:090]:   Height Offset: 0
[11:17:01.531][C][ili9xxx:099]:   Color mode: 16bit
[11:17:01.534][C][ili9xxx:108]:   Data rate: 40MHz
[11:17:01.537][C][ili9xxx:110]:   Reset Pin: GPIO35
[11:17:01.537][C][ili9xxx:111]:   CS Pin: GPIO12
[11:17:01.538][C][ili9xxx:112]:   DC Pin: GPIO37
[11:17:01.548][C][ili9xxx:114]:   Color order: BGR
[11:17:01.548][C][ili9xxx:114]:   Swap_xy: NO
[11:17:01.548][C][ili9xxx:114]:   Mirror_x: YES
[11:17:01.548][C][ili9xxx:114]:   Mirror_y: NO
[11:17:01.548][C][ili9xxx:114]:   Invert colors: NO
[11:17:01.553][C][ili9xxx:124]:   => Failed to init Memory: YES!
[11:17:01.553][C][ili9xxx:352]:   Update Interval: 1.0s
[11:17:01.554][E][component:144]:   display is marked FAILED: unspecified
[11:17:01.554][C][ledc.output:150]: Output:
[11:17:01.565][C][ledc.output:151]:   Pin GPIO16
[11:17:01.568][C][ledc.output:152]:   Channel: 0
[11:17:01.568][C][ledc.output:152]:   PWM Frequency: 1000.0 Hz
[11:17:01.568][C][ledc.output:152]:   Phase angle: 0.0°
[11:17:01.568][C][ledc.output:152]:   Bit depth: 14
[11:17:01.568][C][light:088]: Light 'Backight On/Off'
What does the
refer to?
Have I missed a Breaking Change in the Device Builder Changelogs?
Regards, Martin
EspHome 2025.9.3 - ESPHome - Home Assistant Community
Not sure if it’s related but there are issues in the latest release.
Perhaps your issue is not the same ?
Just compiled one of my ili9xxx devices and had no issues.
Maybe post your yaml? May be a clue in there.
Dhu… False alarm. Sorry… :flushed:
Power cycled and the error went away.
Regards, M.
