New errors with the official Roborock integration
I have been happily using the Roborock integration for a few months now. Recently, this error starting cropping up:
vacuum_areas: Error executing script. Error for call_service at pos 1: Error while calling SET_CUSTOM_MODE
My code:
  vacuum_areas:
    sequence:
      - action: vacuum.set_fan_speed
          fan_speed: >
            {% import 'common.jinja' as c with context %}
            {{ 'balanced' if not c.ethan_is_sleeping else 'quiet' }}"
          entity_id: vacuum.remi
      - action: select.select_option
          entity_id: select.remi_mop_intensity
          option: "off"
      - action: vacuum.send_command
          command: app_segment_clean
          params:
            - segments: "{{ segments }}"
              repeat: 1
Sample invocation:
  vacuum_living_room:
    sequence:
      - action: script.vacuum_areas
          segments:
            - 15
This has worked for a long time without issue, and I haven’t changed anything recently. I scoured the release notes in the previous HA release but didn’t find any breaking changes.
I am just curious if others have hit this. I will file a bug on Github later today once I rule out something stupid that I am doing.
Cheers
Matt
Hmmm very interesting. I also see this in the logs which I guess explains that I am getting rate limited:
Using the cloud API for device (ID redacted). This is not recommended as it can lead to rate limiting. We recommend making your vacuum accessible by your Home Assistant instance
I have changed nothing and this has worked for a long time - so I shall investigate more to see what is going on!
Ah. Looks like HA might be using an old key when trying to decrypt data coming in on the MQTT pipe. I will file a bug.
  File "/usr/local/lib/python3.13/site-packages/roborock/version_1_apis/roborock_client_v1.py", line 466, in on_message_received
    decrypted = Utils.decrypt_cbc(data.payload[24:], self._nonce)
  File "/usr/local/lib/python3.13/site-packages/roborock/protocol.py", line 161, in decrypt_cbc
    return unpad(decipher.decrypt(ciphertext), AES.block_size)
  File "/usr/local/lib/python3.13/site-packages/Crypto/Util/Padding.py", line 98, in unpad
    raise ValueError("Padding is incorrect.")
ValueError: Padding is incorrect.
  File "/usr/local/lib/python3.13/site-packages/roborock/version_1_apis/roborock_client_v1.py", line 468, in on_message_received
    raise RoborockException(f"Failed to decode {data.payload!r} for {data.protocol}") from err
Edit: maybe related? Roborock integration fails to load on 2025.4.3 or later - "The Lab Status is disable" · Issue #143696 · home-assistant/core · GitHub
@Lash-L , do you happen to have any ideas? I’ve been debugging this without success.
I’m on the latest 2025.7, HAOS.
The integration loads fine (nothing show unavailable).
I have deleted the integration and re-added it (thinking it might update the key or something).
I’ve ensured the QRevo Curv is on up to date firmware.
I ran nc -z from
The HA host to confirm it can talk to the vacuum on the right port, which was successful.
Having trouble figuring out what changed since this has worked for me for months and doesn’t seem to be tied to a release, it just kinda stopped working.
Cheers in advance for any assistance!
Matt
Same error here, I’m on 2025.7
Update… after more debugging, this was the offending issue apparently:
          fan_speed: >
Removing the YAML and just putting the “balanced” or “quiet” string literal works just fine. I have no idea why. Just in case it helps anyone else.
Matt
In my case the error was solved by changing “Balanced” to “balanced”
Thank Matthew, I also just started getting this error. I had been using:
“data:
command: " command: set_custom_mode "
params: 300
action: vacuum.send_command”
for a while without issue. Will need to investigate sending a worded fan level
