so you are saying DECREASE the time constant? Still not sure why I’m only seeing one line though… I thought it was supposed to show both smoothed and unsmoothed?
I’m on phone so can’t calculate, try a couple of different values - you can plot multiple traces on a single graph and compare performance.
Docs to come
and get a config validation error:
Sun Mar 11 2018 14:05:33 GMT+1100 (Local Daylight Time)
starting version 3.2.4
Testing configuration at /config
ERROR:homeassistant.util.yaml:while parsing a block mapping
in “/config/configuration.yaml”, line 143, column 3
expected , but found ‘-’
in “/config/configuration.yaml”, line 151, column 3
Failed config
General Errors:
- while parsing a block mapping
Successful config (partial)
Line 143 is the gr1: line…
UGH NVM I screwed up by plonking it in the middle of some sensors. Doh!
