Hey everyone
I just released my first HACS integration — pCloud Backup for Home Assistant — and it has already been added to the official HACS default repo!
This integration adds pCloud as a storage target for Home Assistant’s built-in backup system.
You can also specify the destination folder in pCloud, default is /HomeAssistant/Backups.
Additionally, it provides sensors for monitoring your remote backups:
sensor.pcloud_remote_backup_count
sensor.pcloud_last_remote_backup
sensor.pcloud_last_sync_status
Installation (HACS)
Open HACS → Integrations
Search for “pCloud Backup”
Install → Restart Home Assistant
Add the integration via Settings → Devices & Services
A more detailed setup guide is available in the README on GitHub.
Feedback welcome
This is my first Home Assistant integration — so feedback, bug reports and ideas are very welcome!
If you like it, a on GitHub would make my day
Just a quick heads-up:
The current version only works with pCloud accounts without 2FA enabled, because Digest Authentication cannot skip the second factor.
I had assumed my dev account had 2FA enabled during testing — turns out it didn’t
And since pCloud currently has OAuth app registration closed, adding full 2FA support isn’t possible yet.
I’ve already contacted pCloud support to request OAuth2 client credentials.
As soon as I receive them, I’ll update the integration to support 2FA properly.
For now: users with 2FA enabled need to temporarily disable it or use a secondary non-2FA account.
Thanks for your understanding — and also for all the feedback so far, this is my first open-source project!
Good news! pCloud has approved my OAuth2 application, and the integration now supports accounts with 2FA enabled
This means you no longer need to disable 2FA or use a separate non-2FA account.
The latest release includes the complete OAuth2 login flow.
Simply update the integration and re-add to switch over.
Logger: homeassistant.components.backup
Source: components/backup/manager.py:585
integration: Backup (documentation, issues)
First occurred: 05:59:12 (1 occurrence)
Last logged: 05:59:12
Unexpected error for pcloud_backup.01KABYCW769EW70GX0CWHHGV2F:
File "/usr/local/lib/python3.13/site-packages/aiohttp/client_reqrep.py", line 539, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 680, in read
await self._waiter
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/backup/manager.py", line 585, in upload_backup_to_agent
await self.backup_agents[agent_id].async_upload_backup(
...<2 lines>...
File "/config/custom_components/pcloud_backup/backup.py", line 441, in async_upload_backup
await self.api.async_upload_file(folder_id, backup_name, backup_data)
File "/config/custom_components/pcloud_backup/api.py", line 246, in async_upload_file
async with session.post(url, params=params, data=form_data, headers=headers) as response:
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 1510, in __aenter__
self._resp: _RetType = await self._coro
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 779, in _request
resp = await handler(req)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 757, in _connect_and_send_request
await resp.start(conn)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client_reqrep.py", line 534, in start
with self._timer:
File "/usr/local/lib/python3.13/site-packages/aiohttp/helpers.py", line 713, in __exit__
raise asyncio.TimeoutError from exc_val
TimeoutError
