New Ikea devices via Zigbee, Yellow won't detect after swap from multiprotocol firmware
I just picked up an alpstuga and a Myggspray from Ikea (no Timmerflotte’s in stock at my location yet).
I realized my Yellow’s Zigbee was in an error state, due to still having the multi protocol firmware on there (I mostly use ZWave, only one or two Zigbee devices in the home), so I got that swapped back over. It immediately picked up a Zigbee outlet that had been configured previously and I verified that’s working.
When I attempt to add new devices, it’s not seeing either the alpstuga or the Myggspray. I did a reset on both (held the system button in until the red light stopped flashing) to put them back into pairing mode and they’re sitting inches away from my Yellow for this step, but the logs are only showing it detecting my existing outlet, no other devices.
I also disabled ZHA, installed the Silicon labs firmware add on, let it run and it said it was already up to date (shows the same on the radio under safe mode when I checked there too).
Is there something else I need to do? Anything I may have screwed up with the firmware swap, that would allow previously configured devices to work but not detect new ones?
I’ve got a SLZB-MR4U coming in a few weeks, but figured I could set this up on Zigbee in the meantime with the Yellow’s radio.
Not wanting make assumptions, are these the legacy Zigbee or maybe the new Matter over Thread that Ikea is rolling out ?
They are the new Matter over thread devices. There are some reports that at least the bulbs can be paired to Zigbee2MQTT, but I would treat these as Matter devices.
Ok, I made an assumption they’d still work via Zigbee. I’ll wait until the SLZB-MR4U arrives and set it up for Matter support instead.
