With a new install of the Heat Pump and the Ecobee (Lite) thermostat, the furnace (gas) is set as Aux, will only come on when the Heat Pump is overwhelmed. Now this thermostat has no access to another temperature sensor for the basement, meaning a 10F+ variance between floors is common. During the cold nights, the heat will come on, raising the temperature around 2F in the basement, but keeping the rest of the home in the desired temperature range (77F-78F, yes, 2 degrees, not the 5 Ecobee thinks is comfort).
With the furnace not coming on and warming the basement, there is no extra heat coming in while it operates, meaning in the very cold months, the basement will most likely drop another 15 to 20F easily. I need to proactively deal with this, as the humidity is landing in the basement from the home due to the temperature down there.
I do have a Midea Dehumidifier in the basement automated to keep it running through "awake hours", using an external thermostat (Aqara) for the humidity to monitor and that is working (thanks to the Midea Integration and the most recent work). It helps reduce the humidity, but obviously does nothing for the temperature.
I was looking for a reliable Home Assistant connectable (through WiFi, ethernet or Zigbee if needed) heater, that can be used to aide in the heating of the basement, as I'm certain that the Heat Pump will be unable to keep the basement in check with the rest of the home.
The home sees all 4 seasons, drastically so in some situations, like 80F+ in the day and 40-60F at night. When the Heat Pump comes on in heat, it is much slower than cooling, meaning the amount of air going into the basement at some point, will lose out to the sheer temperature difference. I've already seen this happen where the basement was 15F colder than the floor above. Right now the basement is 7.4F colder with 1% more humidity than the floor above, while the Dehumidifier has been going solid for over 6 hours.
I'm hoping there is such a thing for a heater, doesn't need to be big, as the area being warmed is 15' x 30' x 6.5' (WxLxH) in size. I saw some on Amazon, DREO, but if it was that small, it'd probably wind up working a lot harder.
So, who has any experience with a WiFi enabled Home Assistant compatible heater?
Thanks for sharing the information!
