New installation on a Pi5 taking forever
I’m moving along from a Pi4 to a Pi5 and things were going rather smoothly until the system started. It’s trying to update but it’s stuck here for over 15 minutes now
2026-09-25 22:47:41.473 INFO (MainThread) [supervisor.homeassistant.core] Downloading Home Assistant Core image, 70%
2026-09-25 23:01:56.528 INFO (MainThread) [supervisor.homeassistant.core] Downloading Home Assistant Core image, 72%
2026-09-25 23:10:41.560 INFO (MainThread) [supervisor.homeassistant.core] Downloading Home Assistant Core image, 77%
Is there a reason for it to be this slow? My network is working fine and so is my internet speed. Any thoughts on this? Is there a way to bypass this update?
15 minutes would be a minimum minimum on a pi.
I usually suggest a couple of hours wait before you hard reset.
Start it in the evening and let it run overnight even better.
Why NOT to buy a PI to run Home Assistant
I waited 5 hours before pulling the plug
It booted…needed a bios update disappeared again but it’s booting up fine now
It’s so much faster compared to a pi4 with 4gb
Thanks!
Hi, good you got it solved!
Please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
