New issue: Received an AF message from an unknown device
What the hay is going on?
Logger: zigpy_znp.zigbee.application
Source: /usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py:929
First occurred: 3:58:20 PM (1037 occurrences)
Last logged: 10:09:07 PM
Received an AF message from an unknown device: 0xf669
Received an AF message from an unknown device: 0xd1da
Received an AF message from an unknown device: 0x4ed1
Received an AF message from an unknown device: 0x8716
and…
Hi
I have these messages too, did you managed to remove them / get to know what are those devices?
I do not remember what transpired after June '21 other than numerous updates. I just checked my logs and there are no zigpy_znp.zigbee.application warnings. My logging level for HA is warn and info for ZIgbee2MQTT…
You have 2 Zigbee adapters ? Because the warnings are for ZHA, and you seem to use Zigbee2mqtt.
No only 1. But you’re correct and maybe that’s how I resolved the errors? I don’t remember now when I changed from ZHA to Zigbee2MQTT but it may have been in June…
hmm i’m using ZHA only and having the issue.
I use 2 adapters, but one coordinator and the other a router.
Then I would say the issue is unresolved and I got around it by changing to Zigbee2MQTT.
No idea what the underlying cause is.
