So I recently had to change my routers IP range from the default 192.168.1.1/255 range to a custom range.
I set a new IP for HA on my router and on HA, which i can connect to.
But despite being on the same LAN Home Assisant now gives me this error: Error: Login blocked: User cannot authenticate remotely
How do I fix this? What do I need to do?
The Laptop I’m using is on the same router/LAN. I have no VPN enabled.
Did you by accident choose a “custom range” which isn’t reserved for private networks hence HA interprets the access as a remote one (and your user is set to don’t allow remote logins)?
