New pi 3b+ supported?
Hello, I did not find any workaround for the 3B+ so far. Switching to a 3B should solve the problem however.
I have used 32bit and 64bit versions.
64bit does still have a few little niggles.
Given what the Raspberry Pi is and the code running, there is no advantage at this stage of using 64bit over 32bit, and it could actually use more resources running the 64bit version.
Did you have any luck with this issue? I have not seen the issue myself, but I have been doing a lot of rewriting of automation lately and I likely have not left it on for more than 2 days without making a change recently.
Hmm… does it sound strange that I had 3B but then moved my SD Card to my new 3B+?
Never had any issues with my installation…
