I’ve downloaded the latest rpi3 image from here: https://github.com/home-assistant/operating-system/releases/tag/4.13 (hassos_rpi3-4.13.img.gz)
and flashed it to a sd card. I’m running on a raspberry pi 3 B+, home assistant starts up fine but I see this error in the supervisor logs and I can’t load the Add-on store page
20-09-16 14:59:06 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
20-09-16 14:59:06 INFO (MainThread) [supervisor.store.git] Clone add-on https://github.com/hassio-addons/repository repository
20-09-16 15:04:07 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Operation timed out after 300002 milliseconds with 0 out of 0 bytes received
20-09-16 15:04:07 ERROR (MainThread) [supervisor.store] Can't load from repository https://github.com/hassio-addons/repository
20-09-16 15:04:07 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/hassio-addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/hassio-addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': Operation timed out after 300006 milliseconds with 0 out of 0 bytes received
20-09-16 15:04:07 ERROR (MainThread) [supervisor.store] Can't load from repository core
20-09-16 15:04:07 INFO (MainThread) [supervisor.store] Load add-ons from store: 0 all - 0 new - 0 remove
I also tried entering the docker containers, ping works fine in both the homeassistant and hassio_supervisor containers, however wget only works in the homeassistant container and not in the hassio_supervisor container.
Could there be some setting that is blocking tcp traffic but allowing icmp on this container? or something else going on?
# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
85450b088084 homeassistant/raspberrypi3-homeassistant:0.114.4 "/init" 51 minutes ago Up 51 minutes homeassistant
051deb70e5ff homeassistant/armv7-hassio-observer:3 "/init" About an hour ago Up About an hour 0.0.0.0:4357->80/tcp hassio_observer
1d28919d0c6b homeassistant/armv7-hassio-supervisor:latest "/init" About an hour ago Up About an hour hassio_supervisor
03f0094c34b7 homeassistant/armv7-hassio-multicast:3 "/init" About an hour ago Up About an hour hassio_multicast
08ab94034786 homeassistant/armv7-hassio-cli:26 "/init /bin/bash -c …" About an hour ago Up About an hour hassio_cli
cb45f24ba9f6 homeassistant/armv7-hassio-audio:17 "/init" About an hour ago Up About an hour hassio_audio
41dbbe560cda homeassistant/armv7-hassio-dns:9 "/init coredns -conf…" 7 months ago Up About an hour hassio_dns
Here is ping and wget on the homeassistant container:
# docker exec -it 854 /bin/bash
bash-5.0# ping google.com
PING google.com (172.217.5.14): 56 data bytes
64 bytes from 172.217.5.14: seq=1 ttl=115 time=14.365 ms
64 bytes from 172.217.5.14: seq=3 ttl=115 time=13.842 ms
64 bytes from 172.217.5.14: seq=4 ttl=115 time=14.459 ms
^C
--- google.com ping statistics ---
6 packets transmitted, 3 packets received, 50% packet loss
round-trip min/avg/max = 13.842/14.222/14.459 ms
bash-5.0# wget google.com
Connecting to google.com (172.217.5.14:80)
Connecting to www.google.com (172.217.9.68:80)
saving to 'index.html'
index.html 100% |******************************************************************************************************************************************| 12880 0:00:00 ETA
'index.html' saved
bash-5.0#
Here are the same commands in hassio_supervisor container:
# docker exec -it 1d2 /bin/bash
PING google.com (216.58.192.142): 56 data bytes
64 bytes from 216.58.192.142: seq=0 ttl=114 time=14.462 ms
64 bytes from 216.58.192.142: seq=1 ttl=114 time=14.254 ms
64 bytes from 216.58.192.142: seq=2 ttl=114 time=14.730 ms
64 bytes from 216.58.192.142: seq=3 ttl=114 time=16.962 ms
^C
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 14.254/15.102/16.962 ms
I haven’t had time to look into this more yet, but I’m still getting errors. I’ve updated to 0.115.2 (not that I expected that to fix it) and I’m running HassOS 4.13. I did manage to manually load the files it was looking for by using git in the homeassistant docker instance, and then copying them over to hassio_supervisor instance. I was able to load some integrations but I see this error in the logs daily:
20-09-23 20:22:30 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-09-23 20:22:30 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-09-23 20:27:30 ERROR (MainThread) [supervisor.store.git] Can't update https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(128)
cmdline: git fetch --depth=1 --update-shallow -v origin
stderr: 'fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': Operation timed out after 300004 milliseconds with 0 out of 0 bytes received'.
20-09-23 20:27:30 ERROR (MainThread) [supervisor.store.git] Can't update https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(128)
stderr: 'fatal: unable to access 'https://github.com/hassio-addons/repository/': Operation timed out after 300011 milliseconds with 0 out of 0 bytes received'.
20-09-23 20:27:30 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 0 new - 0 remove
I’ll bring this up in discord when a get a chance but I figured I’d document it here.
