I’ve had another SD card fail on me and am going through the process of re-installing (again) HA Supervised. I’ve never had any issues before doing this, but today it is crashing.
Here is the relavent logs:
[email protected]:/ha/hassio# ha supervisor logs
22-06-22 20:17:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-06-22 20:17:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-06-22 20:17:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-06-22 20:17:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-06-22 20:17:38 WARNING (MainThread) [supervisor.dbus.manager] Can’t load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-06-22 20:17:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-06-22 20:17:38 INFO (MainThread) [supervisor.host.info] Updating local host information
22-06-22 20:17:38 INFO (MainThread) [supervisor.host.services] Updating service information
22-06-22 20:17:38 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-06-22 20:17:38 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-06-22 20:17:38 INFO (MainThread) [supervisor.host.network] Updating local network information
22-06-22 20:17:39 INFO (MainThread) [supervisor.host.network] Updating local network information
22-06-22 20:17:39 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
22-06-22 20:17:40 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0
22-06-22 20:17:40 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-06-22 20:17:40 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_cli application
22-06-22 20:17:41 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0 - 172.30.32.5
22-06-22 20:17:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
22-06-22 20:17:41 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-06-22 20:17:41 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
22-06-22 20:17:43 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-06-22 20:17:43 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-06-22 20:17:43 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0
22-06-22 20:17:43 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-06-22 20:17:43 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_audio application
22-06-22 20:17:44 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0 - 172.30.32.4
22-06-22 20:17:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-06-22 20:17:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
22-06-22 20:17:44 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-06-22 20:17:44 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
22-06-22 20:17:45 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
22-06-22 20:17:45 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-06-22 20:17:46 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-06-22 20:17:46 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version 2022.6.6
22-06-22 20:17:46 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-06-22 20:17:47 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-06-22 20:17:47 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-06-22 20:17:47 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-06-22 20:17:48 INFO (MainThread) [supervisor.store] Loading add-ons from store: 65 all - 65 new - 0 remove
22-06-22 20:17:48 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-06-22 20:17:48 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-06-22 20:17:48 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-06-22 20:17:48 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-06-22 20:17:48 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - CoreState.SETUP
22-06-22 20:17:48 INFO (MainThread) [main] Running Supervisor
22-06-22 20:17:48 INFO (MainThread) [supervisor.jobs] ‘OSManager.mark_healthy’ blocked from execution, no Home Assistant OS available
22-06-22 20:17:48 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
22-06-22 20:17:48 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-06-22 20:17:48 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-06-22 20:17:48 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-06-22 20:17:48 INFO (MainThread) [supervisor.host.info] Updating local host information
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-06-22 20:17:48 INFO (MainThread) [supervisor.host.services] Updating service information
22-06-22 20:17:48 INFO (MainThread) [supervisor.host.network] Updating local network information
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-06-22 20:17:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-06-22 20:17:48 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-06-22 20:17:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-06-22 20:17:49 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-06-22 20:17:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-06-22 20:17:49 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-06-22 20:17:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-06-22 20:17:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-06-22 20:17:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-06-22 20:17:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-06-22 20:18:03 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-06-22 20:18:03 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
22-06-22 20:18:03 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-06-22 20:18:08 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
22-06-22 20:18:08 ERROR (MainThread) [supervisor.misc.tasks] Home Assistant watchdog reanimation failed!
22-06-22 20:18:08 INFO (MainThread) [supervisor.misc.tasks] Rebuilding the Home Assistant Container
22-06-22 20:18:08 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
22-06-22 20:18:08 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-06-22 20:18:09 INFO (SyncWorker_2) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/generic-x86-64-homeassistant with version 2022.6.6
22-06-22 20:18:09 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-06-22 20:18:14 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
22-06-22 20:18:29 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name=‘Task-47’ coro=<Scheduler._run_task.._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=HomeAssistantCrashError()>
File “/usr/src/supervisor/supervisor/misc/scheduler.py”, line 62, in _wrap_task
await task.coro_callback()
File “/usr/src/supervisor/supervisor/misc/tasks.py”, line 199, in _watchdog_homeassistant_docker
await self.sys_homeassistant.core.rebuild()
File “/usr/src/supervisor/supervisor/utils/init.py”, line 33, in wrap_api
return await method(api, *args, **kwargs)
File “/usr/src/supervisor/supervisor/homeassistant/core.py”, line 330, in rebuild
await self._start()
File “/usr/src/supervisor/supervisor/homeassistant/core.py”, line 283, in _start
await self._block_till_run(self.sys_homeassistant.version)
File “/usr/src/supervisor/supervisor/homeassistant/core.py”, line 466, in _block_till_run
raise HomeAssistantCrashError()
supervisor.exceptions.HomeAssistantCrashError
[email protected]:/ha/hassio# ha core logs
exec /init: exec format error
This last one is particularly interesting. I’ve seen this before where I installed the wrong architecture. I haven’t done that this time. This is a RPi 4 and these are the commands run to get the HA install
wget https://github.com/home-assistant/os-agent/releases/download/1.2.2/os-agent_1.2.2_linux_aarch64.deb
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
dpkg -i homeassistant-supervised.deb
dpkg -i os-agent_1.2.2_linux_aarch64.deb
I copied these directly from the supported install thread.
This is from a debian 11 image downloaded directly from their tested build site: 20220121_raspi_4_bullseye
I’m stuck and hoping somebody has some ideas. I’ve already blown this up and redone it to the SD card reformat level and have the same issue.
