New template format - What? How? Where?
I wish to have template configuration in separate files the same way that the legacy format allows.
Added to configuration.yaml:
template: !include templates.yaml
Taking the following documented example. How should this be modified to live in templates.yaml?
template:
  - sensor:
      - name: "Average temperature"
        unit_of_measurement: "°C"
        state: >
          {% set bedroom = states('sensor.bedroom_temperature') | float %}
          {% set kitchen = states('sensor.kitchen_temperature') | float %}
          {{ ((bedroom + kitchen) / 2) | round(1, default=0) }}
Found this video which still doesn’t appear to explain how to do it. Everything lumped into configuration.yaml.
Still don’t get it. What do I need to do?
Take template: out and move everything left two spaces.
out of interest - do you HAVE to move everything left 2 spaces? I only ask - because my split config is done using include_dir_merge_list and all my files (which work perfectly) maintain the indentation as if sensor, binary_sensor etc was still in the file. But maybe it is the merge part of the function that compensates for that?
That is possible too I think.
No.
as long as you maintain consistent spacing within the included file it will be fine.
Thanks. That didn’t work for me before. Will give it a go.
Nope, you don’t. EDIT: Seems I’m late.
Anybody knows why there is 4 spaces indentation between “- sensor” and “- name:” and not only 2 spaces?
post an example of properly formatted code illustrating what you are talking about.
spacing doesn’t matter as long as the fields line up. THis is valid
template:
- sensor:
                                        - name: foo
                                          state: ...
