New to Home Assistant and having trouble adding my first Z-Wave Switches
I have Home Assistant Core running on an Unraid Docker. I added the straighforward integrations first (ecobee, abode alarm, weather) which were obviously easy. I can’t for the life of me get any of my brand new GE Embrighten Zwave Dimmers or Fan Switches to pair.
What i’ve done so far:
Added Zwave to the configuration mapping my AEON GEN 5 Usb stick and specified a network key.The USB Stick shows up as my 1 node in Home Assistant.
When i press “add node” or “add secure node” (tried both) and then press the Up toggle on my zwave switch i get the following in the log:
2020-06-10 22:44:58.801 Detail, Queuing (Controller) Add Device 2020-06-10 22:44:58.801 Info, Add Device 2020-06-10 22:44:58.801 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0b, 0x7a 2020-06-10 22:44:58.801 Detail, Notification: ControllerCommand - Starting 2020-06-10 22:44:58.801 Detail, 2020-06-10 22:44:58.801 Info, contrlr, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0b, 0x7a 2020-06-10 22:44:58.803 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x01, 0x00, 0x00, 0xb8 2020-06-10 22:44:58.803 Detail, 2020-06-10 22:44:58.803 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2020-06-10 22:44:58.803 Info, contrlr, ADD_NODE_STATUS_LEARN_READY 2020-06-10 22:44:58.803 Detail, Node001, Expected callbackId was received 2020-06-10 22:44:58.803 Detail, Node001, Expected reply was received 2020-06-10 22:44:58.803 Detail, Node001, Message transaction complete 2020-06-10 22:44:58.803 Detail, 2020-06-10 22:44:58.803 Detail, contrlr, Removing current message 2020-06-10 22:44:58.803 Detail, Notification: ControllerCommand - Waiting 2020-06-10 22:44:58.803 Info, WriteNextMsg Controller nothing to do 2020-06-10 22:44:59.291 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x02, 0x00, 0x00, 0xbb 2020-06-10 22:44:59.291 Detail, 2020-06-10 22:44:59.292 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2020-06-10 22:44:59.292 Info, ADD_NODE_STATUS_NODE_FOUND 2020-06-10 22:44:59.292 Detail, Notification: ControllerCommand - InProgress 2020-06-10 22:45:00.162 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x07, 0x00, 0x00, 0xbe 2020-06-10 22:45:00.162 Detail, 2020-06-10 22:45:00.162 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2020-06-10 22:45:00.162 Info, ADD_NODE_STATUS_FAILED 2020-06-10 22:45:00.162 Detail, Removing current message 2020-06-10 22:45:00.162 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2020-06-10 22:45:00.162 Detail, Notification: ControllerCommand - Failed 2020-06-10 22:45:00.162 Detail, 2020-06-10 22:45:00.162 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2020-06-10 22:45:00.214 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x06, 0x00, 0x00, 0xbf 2020-06-10 22:45:00.214 Detail, 2020-06-10 22:45:00.214 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2020-06-10 22:45:00.214 Detail, Node006, Expected reply was received 2020-06-10 22:45:00.214 Detail, Node006, Message transaction complete 2020-06-10 22:45:00.214 Detail, 2020-06-10 22:45:00.214 Detail, contrlr, Removing current message 2020-06-10 22:45:00.214 Detail, Notification: ControllerCommand - Completed
Any thoughts on what i can do to get these added? I have tried factory resets on all of the switches as well and have no luck.
Thanks!
Try remove node, hit the button on the switch, wait for it to finish, THEN add node, hit the switch.
Something similar happens to me! According the log everything goes ok (or at least that looks to me) but the new node is not appearing on the Configure>zWave drop down node list.
So +1 following this topic
