New to Yaml and getting Message malformed: extra keys not allowed
Copied most of this from a site to get the Pixel Display to show house battery data on its screen.
Getting
Message malformed: extra keys not allowed @ data [“state”]
I can’t find a line with [“state”] and cannot see where any extra data is entered around anything with the word state in it.
Can any experienced person help me identify and resolve this error please?
alias: Awtrix Home Battery Charge
description: Publishes the current home battery charge to the Awtrix clock
   - alias: Matrix turned on
     platform: state
     entity_id: light.awtrix_55fe48_matrix
     state: "on"
   - alias: Charge level/mode changes
     platform: state
     entity_id:
      - sensor.victron_battery_soc
      - sensor.victron_system_battery_state
condition: []
     - service: mqtt.publish
         payload: >-
          {%- set charge = states('sensor.victron_battery_soc') |
            float(-1) | round(0) %}
            {%- set mode = states('sensor.victron_system_battery_state')
            %} {%- if mode == "Charge" %}
              {%- if charge > 85 %}
                {%- set icon = 32047 %}
              {%- elif charge > 69 %}
                {%- set icon = 32049 %}
              {%- elif charge > 51 %}
                {%- set icon = 32050 %}
              {%- elif charge > 34 %}
                {%- set icon = 32051 %}
              {%- elif charge > 17 %}
                {%- set icon = 32052 %}
              {%- else %}
                {%- set icon = 32053 %}
              {% endif %}
            {%- elif mode == "Discharge" %}
                {%- set icon = 32059 %}
                {%- set icon = 32058 %}
                {%- set icon = 32057 %}
                {%- set icon = 32056 %}
                {%- set icon = 32055 %}
              {%- else %}
                {%- set icon = 32054 %}
              {% endif %}
            {%- else %}
              {%- if charge > 90 %}
                {%- set icon = 13735 %}
              {%- elif charge > 70 %}
                {%- set icon = 13732 %}
              {%- elif charge > 40 %}
                {%- set icon = 13731 %}
              {%- elif charge > 10 %}
                {%- set icon = 13725 %}
              {%- else %}
                {%- set icon = 13734 %}
              {% endif %}
            {%- endif %} {# Output #} { "text": "{{ charge }} %", "icon": "{{
            icon }}", "progress": {{ charge }} }
            topic: awtrix_xxxxxx/custom/batterycharge
            qos: 0
            retain: false
Your state trigger is wrong.
This is the original posted Automation is this also wrong?
automation:
  - id: awtrix_app_home_battery
        platform: state
        entity_id: light.awtrix_xxxxxx_matrix
        state: on
        platform: state
        entity_id:
          - sensor.battery_state_of_charge
          - sensor.battery_mode
    condition: []
          payload: >-
            {%- set charge = states('sensor.battery_state_of_charge') | float(-1) | round(0) %}
            {%- set mode = states('sensor.battery_mode') %}
              {%- else %}
              {% endif %}
              {%- else %}
              {% endif %}
            {%- else %}
              {%- else %}
              {% endif %}
            {%- endif %}
            {# Output #}
            { "text": "{{ charge }} %", "icon": "{{ icon }}", "progress": {{ charge }} }
          qos: 0
          retain: false
Yes, the configuration variable state is invalid for a trigger. A State trigger can use the configuration variables to or from if you want to trigger only on specific state changes.
The original has a second error on the same line in that the word "on" always needs quotation marks so it’s not converted to a boolean value… that seems to have been corrected in your automation.
OK out of my depth here need to reset and get into yaml another day.
I copy pasted it - I changed the target device/Battery SOC and Battery state.
I was hoping it would be quite straightforward.
I got the automation from [AWTRIX 3] (AWTRIX 3)
I’ll look for another way of doing it.
Thanks for your assistance, much appreciated - I’ll use a notification to drive it periodically until I can allocate a lot more time to get into YAML .
It is… all you need to do is change state: "on" to to: "on"
AWTRIX 3 has misled you; the example contains invalid syntax (State Trigger doesn’t have a state option). Its author has made a mistake.
I doubt another way is as simple as correcting the mistake (replace the word state: with to:).
Many thanks for this :slight_smile:
I was still getting the error message until I changed state: to to: :slight_smile:
And here is where subject matter expertise comes in :slight_smile:
I would have never have picked up the word “state” needs to change to “to” many thanks and it looks like it is running now :slight_smile:
Simple if you know how :slight_smile:
I am getting up to speed with Home Assistant, YAML, and Node Red at the same time.
Having fun with it so trying out pre canned YAML so I can see you it works and get a better understanding of it.
Thank you all for your help!
