Have downloaded image for a new Raspberry Pi 3B+. Used the recommended 32 bit image. Have added network details to USB stick and booted. Pi is visible on network and i can ping hassio.local. However there are no open ports on the pi and i cannot connect via browser to port 8123. Have left overnight and no progress.
Not sure how to go about debugging the problem as i cannot ssh into pi.
Thanks for your suggestions. I’ve tried both Safari and Chrome browsers with caches cleared. Using a high quality Sandisk SD card. Have swapped power supply to 40W dedicated. Unfortunately I don’t have a monitor/keyboard - running headless so not seeing anything!
Wouldn’t matter. There’s nothing on the screen to see but a big blue logo (if I recall). HassOS is meant to be headless- (I am assuming that you downloaded the image file here: https://www.home-assistant.io/hassio/installation/ ).
Yes that’s where I downloaded image from. I’ve now downloaded the 64bit image and so far same issue after approx 1 hour post boot. I’m running another Raspberry Pi with Raspbian and no problems.
Yes, I’ve restarted several times. Overnight I’ve tried 64 bit image with exactly the same results. I’ve booted a standard Raspbian image on this new Pi and it works fine. Thanks again for your suggestions.
