New users - Delayed ON & OFF?
I need to be able to turn 4 relays ON at the same time but turning OFF requires one of the relays to wait 30 seconds after the other three are turned off.
When looking at the documentation, all I see is the “flash” option which I don’t believe is what I need.’
ON → Relays 1, 2, 3 and 4 are turned ON at the same time
OFF → Relays 1, 2 and 3 are turned off. This trigger a 30 second timer before relay 4 is turned off.
Is there a built-in function or do I need to create a script for this (like for Digital Loggers’ “Pro Switch 7”, which uses LUNA)
you need a script
#name it relays_on
script:
  relays_on:
    alias: "Turn ON All Relays"
    sequence:
      - service: switch.turn_on
          entity_id:
            - switch.relay1
            - switch.relay2
            - switch.relay3
            - switch.relay4
#name it relays_off
script:
  relays_off:
    alias: "Turn OFF Relays With Delay"
    sequence:
      - service: switch.turn_off
          entity_id:
            - switch.relay1
            - switch.relay2
            - switch.relay3
      - delay: "00:00:30"
          entity_id: switch.relay4
and to call it
service: script.relays_on
service: script.relays_off
you can use a helper to make an automation input_boolean.relay_toggle
alias: Toggle Relays with Automation
  - platform: state
    entity_id: input_boolean.relay_toggle
  - choose:
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - service: script.relays_on
      - conditions:
          - condition: state
            state: "off"
        sequence:
          - service: script.relays_off
something like this
Another option would be to set up a Template Switch.
thats correct
something like this
template:
  - switch:
      - name: "Relay Group"
        turn_on:
              entity_id:
                - switch.relay_1
                - switch.relay_2
                - switch.relay_3
                - switch.relay_4
        turn_off:
              entity_id:
                - switch.relay_1
                - switch.relay_2
                - switch.relay_3
          - delay: "00:00:30"
              entity_id: switch.relay_4
        value_template: >
          {{ is_state('switch.relay_1', 'on') or
             is_state('switch.relay_2', 'on') or
             is_state('switch.relay_3', 'on') or
             is_state('switch.relay_4', 'on') }}
